Page 1 of 4 1234 LastLast
Results 1 to 15 of 46
    Thumbs up How to install DAS 09/2011 successfuly? --> Solution
    This is only a collection of fixes that made me install DAS 09/2011 properly. All credits to other people.
    First I would strongly recommend maher Oct. XP iso to install Windows. (Please don't ask for the torrent). It's already updated with no problems.
    1. Partition and install Windows XP as Guide2h here:
    http://www.digital-kaos.co.uk/forums...8/#post1241251
    Thanks to zolookas
    2. Update Windows XP device drivers.
    3. Create a Ghost image for your hard disk. (In case if you missed something while installing DAS 09/2011. It will save you much time).
    4. As mentioned by selefkos here:
    http://www.digital-kaos.co.uk/forums...0/#post1295681
    Thanks to selefkos
    Copy DAS 09/2011 DVD contents (NOT the ISO file) to a folder then delete the folder Partitioning from the copied contents. (It's inside stardiag folder).
    5. From DAS 07/2011 DVD copy Partitioning folder to the copied contents of DAS 09/2011 DVD so you will have all of the DAS 09/2011 DVD contents except that Partitioning folder is replaced from DAS 07/2011 DVD.
    6. Create an ISO image for your new copied DAS 09/2011 contents using a sutable utility. (I used MagicISO). Don't try to install it from a shared folder because it'll not work.
    7. Set your DAS and Xentry keys from STAR UTILITIES.
    8. Mount the created ISO file and Install DAS.
    9. Install selefkos fix from here:
    http://www.digital-kaos.co.uk/forums...8/#post1251182
    Thanks to selefkos
    10. Search how to run DAS without Xentry.
    11. Install Xentry.
    12. Extract the attached file to fix photos in Xentry to the F: drive.
    13. Run C:\Programme\OnlineUpdateBG\oubg.exe to download and install the remaining addons. (If it didn't start wait for a while then try again. Don't worry it will start later).
    14. After all addons are installed rename oubg.exe to oubg!.exe so it doesn't bother you about the update if there is no Internet connection. (You can rename it back to oubg.exe anytime you want to get the updated addons if available). Or simply you can set Online Update BG Schedulin Service service to Manual.
    15. Install No Password in Special Function from here:
    http://www.digital-kaos.co.uk/forums...on-fix-231850/
    Thanks to gcs190
    16. I guess you still need some DAS fixes that are on Guide2h and some useful attached shortcuts. Pay attention to Mr. selefkos post here:
    http://www.digital-kaos.co.uk/forums...ml#post1301036
    Thanks to pesona and again to selefkos
    17. Finally, do you want to run DAS for lifetime? Extract the attached file to F: dive just as you did to fix Xentry photos.
    18. Thanks.
    Master Computer Engineer, A+, Network+, MCP 4/2k/2k3, MCSA/MCSE 2k/2k3, MCTS, MCITP Enterprise Administrator, Microsoft Certified Trainer/Systems Engineer, Brainbench, ICDL and starting Ph.D.
    All photos are shown now.
    impactops's Avatar
    If there are 50million ways to install it and 50million people post there way, which one should they follow?
    There is no need to modify the partition folder, it would only complicate things for the novice.
    Impactops
    Quote Originally Posted by impactops View Post
    Impactops
    I tried that without modifying it but it quits.
    DAS lifetime is now included.
    Dec 2010
    Smile hi, zcc
    hi, zcc
    Thank you for sharing a valuable guide to the installation.
    But I have a question.
    Vladimir.CDI Do not have needed the 5011 fix?
    Good luck to you ...
    dlaskarb
    impactops's Avatar
    I have already explained why it does not work without modifying the partiton folder on the other thread
    They don't need time out fix either!!
    Just a proper xentry key
    Quote Originally Posted by dlaskarb View Post
    hi, zcc
    dlaskarb
    Sorry I'm not sure about Vladimir.CDI.
    Smile
    Try making the computer's year to 2013 and start DAS as from your fix.
    Regards,
    impactops's Avatar
    Good too see that the JC Cleaning services propaganda team is still alive and kicking
    I didn't get your point.
    impactops's Avatar
    You provided some time out fix it that is not required and yet you thanked me for mention that is not required
    Even you boss below is stating it, but yet you come to pedal this nonsense here.
    Exclamation
    I thanked you because you are contributing to my post and pointing to something that looks useful. I'm not sure what you are aiming to but I have no boss.
    I tried DAS 09/2011 without replacing the partition folder and it didn't work showing me a report about improper partitions.
    I tried an Xentry key that expired on 2099 and had Xentry work lifetime unlike DAS that needed that file.
    Finally I'm spending time to aggregate posts to facilitate the installation, do you see that a wrong thing?
    Your reply doesn't sound nice to me. I respect you and respect DK as well.
  13. #13
    impactops's Avatar
    Mate, seflekos has already made a post regarding that method, if they want to use it they can.There is no point making a new post about it.What happens if others start making new posts which ones are they supposed to follow???
  14. #14
    gazak allaho khira
  15. #15
    Hello impactops,
    thank you very much for you infomation
    Where can we find the right key for SD 09/2011
    Thank you in advance
