EGR OFF Delphi 1.5 meganeII
Results 1 to 9 of 9
    Default EGR OFF Delphi 1.5 meganeII
    hello everybody can someone help me to remove egr from this map?
    the car is megane 2 1.5cc with delphi ecm
    thank you very much
    Beppe
    Not switched off, but permanently closed. Try it.
    Quote Originally Posted by alexs307 View Post
    I will check it thank you very much
    Beppe
    Dec 2010
    UK
    This will most likely bring up fault as MAF reading will not corrolate.
    Quote Originally Posted by Stanton View Post
    It depends on how accurate is the strategy inside the ECU software. I did once a permanent EGR closing on Kangoo 1.5dci and it worked. Maybe it works here too.
    I said that it is not EGR OFF, it is EGR permanently closed!
    ecu has been programmed after 2 days of use, the ecu is stiil without errors.
    ciao
    Beppe
    Good. Glad to hear it.
    ALGERIA
    Quote Originally Posted by beppe_72 View Post
    ciao
    Beppe
    strange,....
    if alex solution work fine so you don't need to flash the ecu,just close the egr mecanecly and job is done
    Quote Originally Posted by grinovsky View Post
    strange,....
    yes, I agree with you, lets wait some days, after that ( if no dtc will come) I will close egr also with manual way.
    ciao
    Beppe
