yes this what i used,
but make sure with imgburn you 'run as administrator'
Hi friends,
Greetings from China We made serveral tests and found some secrets...
TO FULLY BURN XGD3 ON A 15-CENT-PRICED DISC (very common RICOHJPN-D01-67 media, any brand is possible)
First of all, we must get a Lite-On iHASx24 DVD burner (or their clones such as ASUS DRW-24B3ST and so on) and flash iXtreme Burner Max firmware.
After flash, run ImgBurn 2.5.6.0.
0.As in iXtreme Burner Max official tutorial, turn on Tools -> Settings -> Write -> Perform OPC Before Write, because RICOHJPN-D01-67 media is forced to perform write at least 4x speed.
1.Select "Write image file to disc" as usual.
2.Click "Advanced Settings" button in bottom right corner. (Marked red in screenshot)
3.Open Lite-On panel in Advanced Settings. It is required to click the individual "Change" button if you changed any setting item and a "Success" message will pop up to confirm the change.
- Turn on Online HyperTuning
- Turn on SmartBurn
- Turn off OverSpeed
- Optionally turn on or off Force HyperTuning according to your disc quality
Now you are ready to go! Enjoy XGD3 backups dear friends
Note that in our tests, some discs won't work at all even with all settings done!! Please try and buy another brand of disc if you encounter this.
!!please say if it works!!
press the thanks button on my 1st post 4 the guy, how about a thanks so, i can tell the guy who made it how many thanks he got from one site, in a private message!! i have already give him rep from me but, I'm sure he deserves a thanks aswell from here! if you wanna rep him for yourself then, pm me for the link on where to find him! can't send outside links here.
!!Way Two!!
This will fix it!!!! patch your games with this link http://www.digital-kaos.co.uk/forums...atches-249106/
then flash your ihas with this edited c4evas fw iHAS-124B-AL0S-MKM001MKM003-final_AONE+RITEK+MKM003x2speed.bin then restart your pc or laptop, this is for ihas 124b.
Then
Open IMGBurn and go to TOOLS>SETTINGS>WRITE. Clear the box that Performs OPC Before Write. Then go to TOOLS>SETTINGS>I/O and click Page 2 tab. Move buffer size between 71-73mb, Main Buffer Threshold to 25%, and Device to 50%. Press Ok
Prepare to burn (Write Image File To Disc). On this page you can change the setting to burn at 2.4x and advanced settings (settings area bottom-right of the three icons in that area). Go to Lite-On tab...In the Change For: dropdown-list you will disable Forced HyperTuning, Online HyperTuning, and OverSpeed. If not enabled, Enable SmartBurn. Press OK.
Burn your XGD3 and verify. It should verify at 100%.
This will fix it. the fw i posted is mine with my own link so i know its safe!! if you think its not safe do not use it.
all the edited fw does is lets aone and ritek disks burn at 2.4 speed, this will not ~~~~ your drive up. all dvd burners can burn at 2.4 speed, its just as good as c4s fw!
this will work for everyone, if you dont have a ihas124b pm me and i will edit the other fws so that these disks work for that burner!!!
Last edited by djjwdubz; 19th January, 2012 at 04:24 PM. Reason: (Updated) Two Ways To Burn With Aone+Ritek!!
nice one bro, thanks for letting us no man, now i can get the drive . thanks!!
the only thing is, i use newsgroups and it takes the iso out for me!
i use sabnzbd.exe!!
What's up here?
Are we talking about downloding illegal downloads or?
Confirmed working with an Infiniti 360 Disc ID MBIPG101-R10-65. Burned and verified 100% at 4x GOW3 ISO. Installed to HDD no problem.
As tut states RICOHJPN-D01-67 aone's verifiying 100% by this method, happy days!
y 'run as administrator' y not just dubble click and load img burn ?
it didnt work on arita but i didnt run as administrator will try again later and post again,if not look like i got to go find some verbs
tried again running as admin and still failed on verify at 49%
False alarm. After successfully burning one disc as above. Now I get
E 11:59:03 Optimum Power Calibration Failed! - Reason: Timeout on Logical Unit
E 11:59:03 Operation Failed! - Duration: 00:01:17
I also get write failures using the same discs and Deus Ex ISO that is verified in abgx360. It now fails at the layer break. In the past I have had no problems with these discs whatsoever. I'm using all the suggested settings. I powered the PC off once I started getting the new errors but it is the same afterwards.
Next step is to try some verbs but considerig I am now having problems burning none XGD3 games which I had absolutely no problems with before I'm not confident. If you look up the problem imgburn suggest FW first then media. Maybe the FW has been tweaked so much it will only reliably work with verbs? But it is possible to break drives when trying to push them to do more than they are designed to do???
I'm not having a go at all the work that has gone in to this CFW just relating my experiences so people can save their discs. If only Verbs work reliably that is the way to go and not bother buying cheaper discs. The only thing to suss is the correct settings for the different verb discs to get reliable burns.
just out of interest the problems people are having, are they any particular drive revisions or is it just random ones?
