Results 1 to 8 of 8
    Timisoara
    Default 210 ESL MCU1 identification
    Hello
    my ak400 head a problem and now i need to generate key for an 211. Key data get corrupted ak400 read just 75% from the key, other key will read 100%
    problem was that when come to read ESL it wold read just 1 MCU when i switch to second position read data error
    So i check wire and guess what instead to switch K line between pin 3 and 4 was soldered to switch between 3 and GND
    Noe the problem is how do i know witch one is MCU1 and MCU2
    if somebody can give me the right schematic it wold be very nice
    In attachment is what i read
    Thank you
    vanos batam's Avatar
    Batam-Indonesia
    Quote Originally Posted by clauberty View Post
    Hello
    Thank you
    NO problem if you dont know Mcu1 or 2
    just write this files to your mcu1 and 2
    goodluck
    Timisoara
    Quote Originally Posted by vanos batam View Post
    goodluck
    Thank you so much for your fast answer
    now how do i generate the key if i do not know the cpu nr
    The guide say that have to load CPU 1 EZS + CPU 1 ESL CPU 2 EZS + CPU 2 ESL
    It is not necessary to load ESL ?
    Thank you
    Batam-Indonesia
    send me ezs mcu bin
    Timisoara
    send me ezs mcu bin
    Start to unsolder and read
    Batam-Indonesia
    only mcu 1
    Timisoara
    only mcu 1
    Ok when i read cpu already unsolder
    What do i need to do
    write key bin to NEC
    write MCU1 eep
    put ESL bin that you uploaded in both mcu same file ?
    and ... start the car ? car is 1.5Km from my location
    Can i test on the bench it will unlock the ESL ?
    Thank you
    barelang-kepri
    Default key
    Here you go
    Just write to the keys..
    Put back your mcu into ezs..
