yes it works great!!!
thanks ,that's great,i'll go and try one,and test it
Yes, it works very well in a 3 4 6 8 but not if it comes at all
But beaware with new VW TRUCK. They are on 24V and OBD2 is little different. Unfortunatelly VAS socket is not compatibile.
Hy and sorry for my noob question :
Can we recode the units with this?
My friend have a Q7 2007 and he changed the bord the motor engine and I will change the ECU and wonder what is better to recode the ECU.
VAS 5054A(if we can) or RossTech.
And some one will be kind to explain the procedure? Do I need a code to reprogram it ?
I need to reprogram the serial number, the kilometers ect or what will be the steps?
yes you can change the ecu using vas but you need to know the pin code of the new one
when you bring a used ecu. it was programmed. so you have to read the eprom dump and find the pin code.
know you have two pin code: pin of the used ecu and immo code of the car.
in vas software you can reset used ecu but vas need his pin code. after you adapt it whith immo code of the car
salahmanu (27th May, 2013)
one more question, it is said that now the vas 5054a can work on the Bentley and Lamborghini ,it is right?
You want to lear form us how its work your products?
You sell somthing and you don't know what you sell.
Its working on UDS cars only if its a good clone,you chinese sellers know bether.
i think it can work for cars before 1996....
regards to all
not true that you support all the 5054 car, depends on the vehicle and the protocol, if the vehicle has a UDS protocol can not do a diagnostic(eg. A4 2009 ch 8K not support)
it is important to tell how old diagnostic haead.
