Results 1 to 8 of 8
Thread: Spaces ubuntu
    Oct 2011
    Default Spaces ubuntu
    How can I disable three spaces and keep one only?
    We use ubuntu 11 at school and I 'd like to avoid documents are opened randomly in spaces.
    Umby
    Jul 2010
    The easiest way to do this is
    Open a Terminal and type gconf-editor
    Navigate to apps > compiz-1 > general > screen0 > options
    Update the number of workspaces by changing the values of the variables hsize and vsize, which represent the horizontal and vertical number of workspaces respectively (Set both of them to 1)
    Then close gconf-editor
    The changes are instant, no need for a reboot.
    Be careful not to touch anything else in gconf-editor a you can really confuse the system.
    This worked ok for me on 11.04 however it may be different on different versions of Ubuntu
    V.I.P. VIC
    Mjolinor's Avatar
    Jan 2009
    Burnley Vicshire
    Right click it on the taskbar and set it to only show 1
    Jul 2010
    Right click it on the taskbar is the easiest way if you are running Gnome or Unity in Classic mode but the option is not there in Unity. Or at least its not there on my computer when i switch to Unity. I suppose you could switch to Classic mode, change the setting and then switch back to Unity.
    V.I.P. VIC
    Mjolinor's Avatar
    Jan 2009
    Burnley Vicshire
    Quote Originally Posted by Egren71 View Post
    There are people that use Unity
    Oct 2011
    Thanks but it doesn't work.
    Oct 2011
    Perfect, problem solved.
    Thanks again
    Umby
    Oct 2011
    I was referring to the method of Egren71: it works.
