Results 1 to 15 of 21
    Default VCDS 11.8.0 work witch chinese clone Vag-com
    Vag-com, VCDS BETA 11.8.0 work witch chinese clone (11.3.0) based in ftdi FT232RL.
    Regards.
  2. The Following 12 Users Say Thank You to gezame For This Useful Post:
    adz195 (23rd June, 2020), aitor17 (27th April, 2021), AlexOne1013 (26th May, 2020), antonis106 (1st May, 2019), canteli23 (17th October, 2022), Col19 (17th November, 2019), daveskylark (15th September, 2019), kaimps (6th April, 2019), sselcukk (11th August, 2020), svallecilla (1st June, 2019)
  3. #2
    DK Veteran KenshinPT's Avatar
    PT
    Anyone tested?
    I can't test it because I only have the 10.6.4 release / 11.2.0 beta dump!
    Did it help? Push Thanks below
    ovi_dk's Avatar
    On board
    Default KenshinPT
    Right now i install this version and tryit,all worcks good,mi cable its 10.6 china update to 11.2 and work with 11.8.
    All the best
    If u have the answer say Thank You!!
    Oct 2008
    On Earth
    Quote Originally Posted by ovi_dk View Post
    All the best
    After 5-6 time working yor toll will be down and you'll need to reflash it.
    Belive me there's no dumps for this version.
    The last once are for VCDS 11.2 and 10.6.4 which you just have.
    Good luck
    ovi_dk's Avatar
    On board
    ok,i will use 11.2 if this version dosent work,thank you for advice
    Feb 2016
    searching for this one
    Apr 2016
    Hello.
    I have a clone interface with VCDS 11.8 version. Can I install on it VCDS 11.11.3? Thanks,
    Apr 2016
    i dont think so....
  10. #9
    Feb 2018
    Quote Originally Posted by gezame View Post
    Regards.
    Is this version the right version to 118 Cable?, im trying to use the 17.8 but cant connect to the car.
    Im trying to download but ask me to put a reply, i hope that now i can download it.
    Thanks!
  11. #10
    Oct 2018
    I will test
  12. #11
    Jan 2019
    holla igual me pasa no encuentro el software
  13. #12
    Jan 2019
    tank you de mucha ayuda no he podidocomprar el vas
  14. #13
    Sep 2019
    Thanks for the share bro.
  15. #14
    Jun 2020
    Hello, is the version 11.8 still in function?
    I have an old key VAG 11.8 and a POLO 2005 but I don't have the VCDS 11. and the latest version doesn't function with this old key.
    Thank you for your advice.
  16. #15
    Jun 2020
    thank you very much
