Page 1 of 11 123456 ... LastLast
Results 1 to 15 of 158
    Sep 2009
    Ferizaj KOSOVA
    Default VAg Eeprom programmer 1.19 false or true????
    I have found this software in web.
    i have instaled in my computer its says its virus i have turn off my virus protect software Avira just to see what is this software ,when i click in icon its says
    You need license key to run this aplication
    Machine ID :07-F6-CE-0C-A8-33-CB-F9
    Does anybody have this software cracked so we can work like other versions like 1.13 and 1.18 of Vag eeprom programer
    Sep 2009
    Ferizaj KOSOVA
    hers is software for download
    nikicom locksmith shop
  3. The Following 10 Users Say Thank You to nikifer For This Useful Post:
    clickerfux (22nd July, 2020), goran7 (11th March, 2025), jm6734 (27th January, 2019), joe06 (13th March, 2021), Papiti56 (15th December, 2020), Pe Germany (6th May, 2020), roefie (12th November, 2020), turnerbrown (20th December, 2024), velisav (8th November, 2024)
    Sep 2009
    soft have protect;.
    DK Veteran dune85872005's Avatar
    Sep 2011
    spain
    can use disk volume serial numer changer and change the number of disk late i will upload a license key for you
  6. #5
    ahadi's Avatar
    Sep 2009
    Quote Originally Posted by dune85872005 View Post
    http://technet.microsoft.com/en-us/sysinternals/bb897436
    I think this soft you mean . which serial to change to .
  7. #6
    Nio's Avatar
    Mar 2010
    This software is here on DK. Search and will find it without license.
    Regards
    "IF YOU THINK PROFESSIONAL PEOPLE COST YOU A LOT, IS BECAUSE YOU DID NOT KNOW HOW MUCH WILL COST YOU AN UNQUALIFIED"
  8. #7
    dimitar's Avatar
    Quote Originally Posted by Nio View Post
    Regards
    Not this one
    50w Soldering Iron
    Chisel
    Sometimes Hammer
  9. #8
    Jun 2010
    were do you purchase this SW from
    cant see it being expensive
  10. #9
    blackpirate's Avatar
    Jun 2009
    Use this installer and test if the sw its working or not!!!
    Download VAG.exe from Sendspace.com - send big files the easy way
    Srry, i've forgot to add the shortcut option....
    well u can do it manually!:P
    Cheers
    If freedom is outlawed, only outlaws will have freedom!!!!
  11. The Following 2 Users Say Thank You to blackpirate For This Useful Post:
    elephantul (7th April, 2013), rossoelab (7th April, 2013)
  12. #10
    Jun 2009
    btw: i think its false.
    i saw inside it ASCII ""vag 1.18"!
  13. #11
    V.I.P. Master of the IMMO
    lupu_sandu's Avatar
    Jul 2009
    Far far away
    BP: They added some new module in Bosch section, like RB4 (decrypter/encrypter), set mode to 4 or 6, Touareg and EDC15.
    Today i will test and post results.
    4C7570755F73616E64755F696D6D6F5F736F6C7574696F6E73
  14. #12
    lee_hdi's Avatar
    Sheffield
    Still work with KKL serial interface, or need another one?
    Don't let failure go to your heart, don't let success go to your head.
  15. #13
    Jun 2009
    Donno bros, i didnt tested the cracked.exe on interface+car!
    so , please do it on your own risk!
    cheers
  16. #14
    tiguan's Avatar
    Sep 2009
    Default Thanks VAG.EXE 1.19
    Quote Originally Posted by blackpirate View Post
    cheers
    BP: Thanks for VAG.EXE 1.19, Tomorrow I will try this test on Car + KKL /Serial USB Interface
  17. #15
    H.Wessel's Avatar
    Jul 2010
    cheers
    I tried it ten minutes ago, with skoda fabia VDO 2004 and A3 1999 VDO can not connect.
    If I open the dump of the same dashboard readed by a programmer work fine.
    I used usb interface.
