Results 1 to 11 of 11
Hybrid View
    DK Veteran aidyk's Avatar
    Feb 2010
    europe
    Default 406 2002 90hp hdi ignition stays on and no brake lights.?
    this car came in with no brake lights and ignition wont switch off, sometimes if you touch the brakes car switches off with key out but not always. anyone come across this before ? possibly save me a load of checking . im guessing a fault in the bsi or engine fusebox.
    smirnoff_rules's Avatar
    Mar 2008
    birmingham
    have u taken the brake light bulbs out , just thinking if someones but the wrong bulbs in , say a single instead of a double ? l know the escorts if they had the wrong bulb in and sidelights where on u couldnt switch the engine off without turning side lights off ,,
    Feb 2010
    europe
    oh aye yes i know wat your saying ok ive came across that alot over rthe years myself no nothing as simple as that, brake lights are ok in conjunction with side lights, cheers anyhow boss .
    Meat-Head's Avatar
    Quote Originally Posted by aidyk View Post
    switch off, sometimes if you touch the brakes car switches off with key out but not always. .
    It's Frogench - so guess two faults.
    1) remove key Stall it - see it kills the ignition - if it does - cut the small
    D+ wire on the dynamo - fit a diode facing towards the dynamo
    2) *THINK* brake light switch is ~~~~ed - or manky fuse
    3) CHANGE ALL 5 AMP FUSES BEFORE DOING READING ABOVE SUGGESTIONS.
    Feb 2010
    europe
    Quote Originally Posted by Meat-Head View Post
    stalling it doesnt switch ignition off tried all that, its as if a couple of wires are rubbed together and corroded etc plus the fact it 1st happened with torential rain the other day !
    Meat-Head's Avatar
    in that case thanks to member Ashraf11776699999999 for this tip - footwell - loom rotten and chafed
    Feb 2010
    europe
    heard of this before somewhere just to the right of the throttle isnt that right.? mmmm hada have a gawk there indeed.
    Ashraf6119's Avatar
    Nov 2009
    UK
    Agreed with MH have a look under the drivers footwell very common wiring getting rotten also causing ABS wheel speed sensors fault or, non start some times. so worth having a quick look
    Edited: Even the Ignition loom do give problem sometimes
    Thanks Ash
    Oh yes if my post was helpful than Please don't forget to press the Magic word Thanks
    Meat-Head's Avatar
    Quote Originally Posted by Ashraf6119 View Post
    HI
    WE ONLY KNOW ABOUT THIS FAULT - THANKS TO YOU ASHRAF11696879087657647.2
    PERHAPS THIS IS BECAUSE WE ARE BOTH MEMBERS OF THER WORLDS BEST WEBSITE
    HTH
    MEAT
    Feb 2010
    europe
    right got back to this there now, lifted the trim and carpet at drivers side footwell. car still running and keys on drivers seat abs light on in dash etc .
    the floor was soaking customer had told me he had went through few bits of floods etc. multiplugs were soaking i gave them a shake and car stopped. with excitement i thought id come post my findings. good work guys ashraf and meaty. ! much appreciated.
  11. #11
    Meat-Head's Avatar
    if only every job in the motor trade was like that - shake wet multiplug post on DK - job done
