Results 1 to 15 of 21
    Jun 2009
    Default WRITE PRocessor mc68hc908az60
    i want to move one flash from one processor to another ,but the problem is that i read them but i can not write to them .
    i use xprog,upa and codecard but same problem .
    the car is vito and i want to make flash to another new processor .
    any help about security bytes .
    DK Veteran markony79's Avatar
    Jan 2009
    Sweden
    this not have security bytes there
    just up all legs where cables is going and you will read it
    can you send me the Pdf for Codecard for this mask processor
    Jun 2009
    i can read it but i cannot write to it , it looks locked by security bytes and i am asking if someone knows the security bute for vito dashoboard
    Jan 2009
    Sweden
    Quote Originally Posted by gadroulll View Post
    Not have security bytes there!!!
    Yes, having security bytes if talking about the Flash and presuming that gadroulll knew what they are on this MCU as he needs flash writing. But this is not of that concern. see this thread
    http://www.digital-kaos.co.uk/forums...-0j66d-222433/
    Land of Rocks
    Dont waste your time.
    ETL is your solution.
    Upa and xprog cant write the flash dump.
    romania
    if you are tryng to write in a NEW chinese mcu then stop ..... mcu is bad .. they have this problem now .. can not write inisde
  8. The Following User Says Thank You to answers For This Useful Post:
    Dalplex (10th February, 2018)
    Quote Originally Posted by answers View Post
    +1 The reason of this is in my post#5 link
  10. #9
    Jun 2009
    my dump ia that probably eepro has been erased before used .
    i see that my upa do not make erase flash ,why?
  11. The Following User Says Thank You to gadroulll For This Useful Post:
    ktome (25th April, 2020)
  12. #10
    Jun 2009
    this is a reason for that but if i know the security bytes normally must works
  13. #11
    Is the dump in post #9 read by UPA 'all memory'? If read correctly I can see the EEPROM blocks (block1 & block2) has some problem. I will help you to analyse, please also post the dump of the donor too to see how many blocks used. the receiver MCU 2J74Y? sec. bytes of this dump are all '00'
    UPA almost not support Flash programming with two cases exception, hc908as60 and hc908az60. that's why the 'Erase Flash' button not active. but never try that UPA flash programming on these two work properly.
  14. #12
    ozibo's Avatar
    turkey
    security byte this mcu
    $F9-$F1-$F9-$F4-$F9-$F7-$F9-$FA=MC68HC908AZ60 (2J74Y)
  15. #13
    Jun 2009
    i can write to eeprom 1 adress 800-9ff
    i can not write to eeprom 2 600-7ff
    i try to write only fe00 registers and i can not do it.
    so the processor is locked in flash and to eeprom 2 .for this reason i can not write to it .
  16. The Following User Says Thank You to gadroulll For This Useful Post:
  17. #14
    ozibo's Avatar
    turkey
    enter the following security byte
    F9-F1-F9-F4-F9-F7-F9-FA
  18. #15
    Land of Rocks
    If you want to solve the problem goto post no 6.
