br.balazs (28th April, 2018)
My dump is tuned, dump your stock?
Thank you! I'll try.
Hello friends!
There is a car VW Golf V 2006 2.0l TFSI MED9.1 200HP with DTC 001537 - Internal Contorl Module: Memory Check Sum Error. I read the firmware with MPPS and WinOLS 1.721 showed that all CS OK. Perhaps the car was Tuning, but the owner just does not know about. Tell me please how to solve this problem. Thanks in advance.
You need full BDM read this ECU for repair with same version of dumps. You need MCU, FLASH, EEPROM.
Yes. Chances are that way.You need full BDM read this ECU for repair with same version of dumps. You need MCU, FLASH, EEPROM.
WANTED full of such a ECU!
Nothing more has no effect.
There is a version that is sufficient to correct the data in eeprom
Factory software upgrade if available might save the ECU. I had success once with a MED9.1 from Octavia RS.
Go to the dealer.
Anybody can help me with eeprom? I need repair dump
Hello
Why everyone wants to repair a software that is original buggy and has an official recall from the dealer for upgrade?
after 115K 0010 there have been at least 3 updates to 0040. Maybe even higher.
Go to the dealer, get a free update and the problem is solved!
greetings,
filecloud
Thank you! Problem solved - updated with VAS5054A to version 40 - error removed.
Thank DeusEx!
Deusbrest )
