Results 1 to 8 of 8
    Default incompatable SKIN
    I've just installed an incompatable skin and now stuck in a reboot cycle, can anyone help?
    DK Veteran freck's Avatar
    Jul 2008
    Dark side of the Moon
    Reflash it... serial cable jobby
    Freck
    Thanks reflahing now, what a pain
    DK Veteran Rodbouy's Avatar
    When the box boots, you have enough time to log in via dcc and remove the skin, this will restore it back to default skin saving you to re flash.
    /usr/share/enigma2
    toysoft's Avatar
    Nov 2008
    Do as Rodbouy tells, remove the folder of the skin on /usr/share/enigma2, it will then use the default skin.
    TS
    Mar 2009
    Just done this and thought I had 2 re flash ideal will give it a go thanks
    Mar 2009
    Just done it and worked like a dream. Saved a lot of flashing
    Thanks griff
    Sep 2010
    it's only the enigma 2 GUI that is in a bootloop so when ever you box goes into a loop you have all the time in the world to login with either a FTP connection or start a TELNET session.
