I can help with good dpf off
Someone here had already work with siemens PPD 1.2 DPF + Chiptuning of Seat Leon ?
Model is year 2008,2.0 Tdi 170 pd.
Who have experience with it?What gain do you really have or this is completly unnecessary?
This car is already tune but i want informations about DPF.
Thanks for informations
Best regards
Original Kwp2000+ and other...
No stress for all !
of course there is difference with dpf on and off. Who invented the DPF was just a barbarian in my opinion.
when the exhaust gas through the FAP they traveled an area size aquivalente to 3x area size field football
and the materials used in its manufacture are too expensive
that's why it cost very expensive to replace a damaged DPF
and the people ask for DPF OFF becose it cost cheaper than to get a new one
grinovsky ... go study a little bit more about the chemical processes involving rare metals like Platinum / Phaladium / Rhodium etc. inside the dpf, become an engineer and a master of sciencee then come back and argue with me about how useless is the dpf.
i never argue a fanatics,i only correct them when they say stupidity
Ecology, ecology.....Think DPF is in this way.
But In performance way ?
This car is already tune, professionaly made, but i hesitate to remove it, because some people tell "yes i sense difference " ..other not...
What do you think of it ?
No stress for all !
I said there is a difference with dpf and without dpf ...
do you say there is no difference?
when you get dtc about damaged fap,try first to forced the regeneration by interface diag to solve the probleme,if not solved ,ask your client what he want to do,change it by a new one or fap off,it's his car,so it's his decesion
i have diagnostic many cars with good FAP,the pression turbo is perfect with FAP
whow can be a defference ,what's change after remove FAP?no think,the pression turbo is the same
Thanks.But all my friends don't carry with us VAG VCDS or other diagnose tool
That's why they decide to make DPF off with DPF substitute and they sense NO difference.
But they don't have modded car, just DPF.
Now i think like Grinovsky, it is just for no problem with DTC and don't other thing.
Just only one problem, EGR...
Thanks at all and best regards
No stress for all !
Someone have a good solution for tdi 170 siemens ppd (A3 2006) ,i pay for it if necessary ?
thx
