Results 1 to 5 of 5
    Senior Member gixxer's Avatar
    Mar 2009
    Europe
    Exclamation FIESTA NOT START P0200
    Hello
    I have a Ford Fiesta '03 1.4 TDCI I changed fuel filter then first starting and run idle speed 10 min, then I off and again not start. Fault code P0200 I check wiring ECU to Injectors , injector resistance ok. fuel pressure ok.
    Between injector cable (2pin plugged) not signal, only between battery+ and injektor - while starting engine.
    Please help that why not starting car???
    THANKS
    smirnoff_rules's Avatar
    Mar 2008
    birmingham
    lm sure they sell modified injector wiring for these , l know the earlier ones the injection pipes uses to brake and let air in , not sure the year they changed them
    antwnhszr's Avatar
    macedonia is greek....
    Quote Originally Posted by gixxer View Post
    Hello
    THANKS
    my friend Listen to what has happened ..... when changing the oil filter the first engine runs .... for a while .. This is because the circuit of the fuel is no air which passes the injector and the fuel so it can come out .. the solution of the problem is to do a little vaporisation ..... unscrew the injector and press start
    Mar 2009
    Europe
    Quote Originally Posted by antwnhszr View Post
    The engine ran 10-15 min and I turn off ignition...
    Thanks but I try this before
    Mar 2009
    Europe
    ECU was bad...
