Results 1 to 1 of 1
    Member steve67474's Avatar
    Default pin lock on menu access
    Hi guys
    I have a cable box out here in sunny barbados that has been set up for card sharing. the guy has locked it down so I cant access the menus. I want to have a look at the config files and maybe save the image. Is there any way I can bypass or reset his pin.
    cheers guys. I will have a rum for you later
    Update... OK did a bit more reading and think I have a solution to reset pin which is ftp into var/tuxbox/config/enigma look for pin/setuplock=ffffffff change to 000004d2 (1234) save, then power box off wait 20 secs power on and it should reset. I say should because he has also changed the root password so I cant ftp into box at all. Is there any way I can access this ~~~~in box without reloading it. cheers again guys
    Learn how to hold a bear with a mic in your hand Kylie LOL
