    calibracbr's Avatar
    Aug 2015
    Moon
    Quote Originally Posted by ukash View Post
    could anyone of you be kind enough to help me with :
    A3 8P 2008 2.0 TFSI 200HP DSG
    to make it
    stage1 with pops&bangs?!
    pops and bangs for you
  2. The Following User Says Thank You to calibracbr For This Useful Post:
    ukash (3rd February, 2022)
  3. #16457
    Nov 2021
    Default Vectra c 1.9 z19dth stage 1
    Cześć!
    Potrzebuję etapu 1 sw1037384336 hw0281012868
    Dzięki!
  4. #16458
    mainhattanracin's Avatar
    Oct 2020
    Kosovo/Albania
    Default MB C250 CDI C205 Stage 1
    Can anyone make me a good Stage 1 for my C205 / W205
  5. #16459
    Feb 2022
    Europe
    Default 06A906018R stage1
    I might very soon inherit of a 98 Golf GTI 1.8T, however it has a 06A906018R ECU instead of the more common 06A906018CG.
    Is there a stage 1 available for this 06A906018R ECU ?
    I can find two software version: 358109 and 359591, are they compatible ? The files avec very different…
  6. The Following User Says Thank You to Bob1973 For This Useful Post:
    parasitfr (10th May, 2023)
  7. #16460
    Dec 2020
    Quote Originally Posted by calibracbr View Post
    stage 1 for you,
    Thank you, its working and power is good. Problem now is that automatic shifts delayed and not really smooth anymore.
    Is there a way to optimize that?
  8. #16461
    Feb 2022
    Hey Guys,
    Does anyone have a stage 1 for 074906021L (MSA15.5) 2.5TDI ACV T4?
    I attach original file.
    Thanks in advance!
  9. #16462
    Jan 2017
    Exclamation audi 2.5 tdi ake 180 a/t
    audi 2.5 tdi ake engine . please stage 1 if possible
  10. #16463
    Feb 2022
    Europe
    Quote Originally Posted by Bob1973 View Post
    Follow-up, replying to myself.
    So after a few days of digging, I found a stage 1 for a 06A906018CG on this forum and by comparing with the original file I was able to list all maps modifications.
    I then found the matching tables in the original files for 06A906018R 358109 and 359591 and made the same modification. Then using WinOLS 2.24 I corrected the checksum.
    As soon as I get the car I will report back. Anyone willing to try is welcome to report back too.
    The question remains as to what the difference between 06A906018R 358109 and 359591 is ?
    Edit : Stage 1 files have 150hp in the name but it’s probably more like 190hp/300Nm…
  11. The Following 2 Users Say Thank You to Bob1973 For This Useful Post:
  12. #16464
    gomku's Avatar
    May 2017
    Default audi
    Quote Originally Posted by trt2020 View Post
    stage1 for your car. pass pm after thx and rep.
  13. The Following User Says Thank You to gomku For This Useful Post:
    trt2020 (24th February, 2022)
  14. #16465
    Jan 2022
    Can anyone make me a stage 1 or slightly more with pop and bangs please?
    audi A3 2.0 tfsi axx
  15. #16466
    calibracbr's Avatar
    Aug 2015
    Moon
    Quote Originally Posted by jamiewilliams93 View Post
    pops and bangs
  16. The Following User Says Thank You to calibracbr For This Useful Post:
    jamiewilliams93 (8th February, 2022)
  17. #16467
    Nov 2020
    Hi, Please can someone send me original map? BMW e60 530xd 170kw 2006. thank you
  18. #16468
    Oct 2016
    Za Bugrom
    Quote Originally Posted by kotos96 View Post
    I did EGR OFF and DTC 4D32 OFF for you
    Upload mods and let me know if everything is working properly
    Hey, i record twice and read twice after recording there is some CHANGES in the file if i read it after writing it!
    Is it normal?
    REPHRASE, after writing your file i read it from ECU and the file in ECU is different, is it OK for it to be a little different?
    File that i see is attached below!
    EDIT!
    Write file to ECU as said above but THROTTLE BODY still moves when vehicle is warm but NOT hot, so after driving 5 minutes throttle body still closes but after driving 10 minutes i cannot see it moving anymore!
  19. #16469
    Feb 2022
    Hello.
    I kindly request you to turn off the EGR and DPF.
    If possible I would also like Stage 1.
    Thank you
  20. #16470
    Jan 2022
    Quote Originally Posted by wezyk View Post
    Hello.
    Thank you
    Here is your file with EGR and DPF off. Don't forget to press thanks+rep. Cheers
  21. The Following User Says Thank You to mikeshustec For This Useful Post:
    wezyk (9th February, 2022)
