    Aug 2023
    Hello.Could someone do stage 1 for my own bussines car. Dacia dokker 1.5 dci
  2. #18407
    Sep 2023
    Hello everyone, you can do stage 1 and EGR off the car in this VW with tiptronik. Thank you for your help 😀👍
  3. #18408
    Nov 2018
    Hi!
    Pass in pm
  4. The Following User Says Thank You to Szedi87 For This Useful Post:
    Lukasz778 (6th September, 2023)
  5. #18409
    Jun 2017
    Hi Could someone make stage1 for audi a4 b6 1.9tdi?
  6. #18410
    Sep 2023
    finaly something useful
  7. #18411
    Nov 2018
    Hi!
    Pass in pm!
  8. #18412
    Oct 2015
    Lithuania
    Hello,need safe stage 1,vw tiguan 103kw,cffb
  9. #18413
    London
    Hi guys,
    just a quick question first if I may before I post my file.
    I have 2016 VW Crafter with a 109 HP/80 kW CKTB engine. My understanding is that the 136 HP/100 kW CKTC engine is the very same hardware ant the only difference is that VW sold the car with a different ECU software. If this is the case than flashing a CKTB ECU with a CKTC software would mean a "OEM factory tuning" right away, isn't it?
    So basically, a "stage 1" tuning for BOTH engine would mean a healthy 164 HP/120 kW tuning?!?
  10. #18414
    London
    Quote Originally Posted by yourmate View Post
    Hi guys,
    2016_CKTB_109_crafter_dpf&egr_off.zip
    Okay, so this is the file for my 2016 CKTB 109HP Crafter.
    DPF and EGR already switched OFF, I would like to ask if you'd do it more powerful please.
    Many thanks,
    EDIT: It has the 6 speed gearbox
  11. #18415
    Jun 2016
    good day i looking for an original file for toyota prado 89663 60x51
  12. #18416
    Dec 2012
    Hi.Could someone make a good stage1 for a BMW E91 320D edc17c50 Automatic 184PS?
  13. #18417
    Mar 2023
    Audi A4 B6 1.8T QUATTRO AVANT BFB ME7.5
    If some1 could do s1
    DOBRAKOPIA1.8.zip
  14. #18418
    Question
    Can anyone modify SAI map for me on this ecu. This is me7.1.1 ecm from audi s4 4.2 Need SAI map set to all zero's. SAI map If im not mistaken is MSLUB. I believe map location is at or around 0x1B0E0.
  15. #18419
    Jun 2023
    Not much progress over a month of different changes.
    Med17.1
    1037516953
    2.0 tfsi
    Stage 1 with pops & bangs please!
    Thanks in advance!
    I've probably bench flashed my ECU over 100 times trying
  16. #18420
    Sep 2018
    Default a3 1,6tdi pcr2,1 could start increase injection
    Hi .Please increase the injection duration for cold and warm starting. Thanks for your help. Regards. Or what is the adres map address?
    and extending the heating time of glow plugs from 0 to 40 degrees Celsius by +3seconds more
    A3 8p 11r 1,6tdi 105ps ..023JK
