    Aug 2023
    Germany
    Default :)
    Hey Guys i have an problem and really would appreciate help.
    The Car got a Stage 1, AGR and DPF is deactivated, i really dont want it anymore and want to undo all of it.
    Just normal original Software again
    Ive red the EDC17CP46 with KESS Tricore
    Car Info:
    P365 - Bosch EDC17CP46 Mercedes
    CR60-642LS-7EL0-Ch4_Q2-212WA-LS-EU5OP_AJ12_4x4-ME08
    NameAIMLER E350 CDI 4MATIC
    Prod:2012
    Motor:OM642.858
    2987cm3
    265PS
    195kW
    Thanks for the Help
    Best Regards!
  2. #18482
    Sep 2023
    reunion 974
    hello I would like to modify my file in stage 1 or stage 2 please
  3. #18483
    Sep 2023
    Default Request remove EGR DPF, DTC for Mercedes
    For Mercedes W211 E280 diesel Engine OM642 year 2006
    Attached is the original ECU file
    Thank you
  4. #18484
    spiridonas's Avatar
    Default Renault Megane 3 1.5dci sid305
    Hi please can you tune in stage 1 the Renault Megane 3 1.5dci sid305.
    (My file is with dpf_egr_off and working fine)
    Many thanks in advance.
  5. #18485
    Jan 2023
    Talking 2006 chrysler 300crd
    hi mate , i have a 2006 chrysler 300 crd i have had a remap done in the past with egr turned off but have since upgraded intake ect. if you could have a look and help with dpf delete , if you could spare a little time to help would be appreciated , thanks!CHYSL 1 read.zip
  6. #18486
    Jul 2016
    FRANCE, 22
    Quote Originally Posted by donatas91 View Post
    Attachment 987190hello need stage 1 tnx
    Here it is stage 1 give me a feedback after tried.
    Thanks + rep for pass
  7. #18487
    Mar 2020
    IMENI NR37
    Default stage 1 egr off swirl of remap
    Hello.Please stage 1+egr off +swirl off.Thankyou.
  8. #18488
    Oct 2019
    Quote Originally Posted by tonybris View Post
    Thank you
    pass pm after thanks+rep
  9. #18489
    Member fanatic1992's Avatar
    Jun 2019
    Topola - Serbia
    Default alfa romeo 147 1.9 jtd
    Please stage 1 for more power Alfa romeo 147 1.9 jtd
    If my post was helpful than please click on Thanks & Reputation.
    MMS Flex Slave and Kess v2 Master clone
  10. #18490
    Nov 2017
    Dobruja
    Solved. Thanks for nothing.
  11. #18491
    Newbie Spawnb91rlf's Avatar
    Dec 2015
    Europe
    Hello
    Can Launch Control DSG DQ250 be activated without ESP installed on the car only with ABS?
    Thank you
  12. #18492
    Apr 2020
    Quote Originally Posted by pasmas974 View Post
    ...file for yoz, pass after thx and rep
  13. #18493
    calibracbr's Avatar
    Aug 2015
    Moon
    Quote Originally Posted by hanskaschpa View Post
    Hi guys! Here I have a DCM 6.2V org file.
    Can make anyone here a stage1 solution?
    V-Read file: PCMflash
    stage 1 for you
  14. The Following User Says Thank You to calibracbr For This Useful Post:
    hanskaschpa (11th October, 2023)
  15. #18494
    calibracbr's Avatar
    Aug 2015
    Moon
    Quote Originally Posted by palika55555 View Post
    Hello, someone who can help me with stage 1?
    CKFC 110KW DSG
    Thanks in advance.
    stage 1 for you
  16. #18495
    Hello, can you help me with Stage 1, egr off and hotstart fix ? thanks
    dumped with KESS
