    Jun 2017
    Default Alfa 159 2.4
    Can someone help with stage 1 with swirls and EGR off pls?
    Alfa 159 2.4 jtd 2006 147kW
    Original .bin attached, thanks in advance.
  2. #18677
    Jan 2020
    Default S-MAX
    Can someone check if map is still original?
    If yes, then please Stage 1 and EGR OFF.
    Car: 2007 S-max 2.0 Tdci 103 kW (140hp)
  3. The Following User Says Thank You to smassher For This Useful Post:
    Tech8Auto (16th January, 2024)
  4. #18678
    Jan 2024
    Default Hi, e46 318d 2003
    Hi. Can someone help with file? e46 318d 2003, edc16c31
    Can someone make stage 1, hardcut and egr off?
    Can be also only stage 1...
  5. #18679
    TheNeiz's Avatar
    Jan 2024
    here is for you stage 1 and egr off, pass in pm after thx+rep
    regards
  6. The Following User Says Thank You to TheNeiz For This Useful Post:
    bs98 (14th January, 2024)
  7. #18680
    Dec 2023
    GB
    hi does anyone have a stage 1 map vw golf mk4 2002 1.8t turbo aum bosch me 7.5 06A 906 032 HJ 0002
    HW 0261207436
    SW 1037362287
    with immo off cat delete sai delete any dtcs cleared thanks in advance
  8. #18681
    qni666's Avatar
    Mar 2019
    Bulgaria
    Quote Originally Posted by bs98 View Post
    I send u one trash file with Driver wish,turbo,limiters touched not stock and write feedback for my work please
    WANT PASSWORD ? PRESS THANKS AND ADD REPUTATION AFTER THAT CAN ASK ME PASS PM
  9. The Following User Says Thank You to qni666 For This Useful Post:
  10. #18682
    Jan 2024
    Quote Originally Posted by qni666 View Post
    I tried both of maps. Your map feels much better with almost 0 smoke. Thank you very much!
    @TheNeiz thank you too, but one from qni666 feels better
  11. #18683
    Sep 2022
    Hi. I would need EGR off and DTC P3008 and improvement of my stage 1 to about 180km. I also have P0000 after FAP removal, but I don't want to ask for too much. Thank you in advance and best regards. Peugeot 407 2.0HDi SID803
  12. #18684
    Dec 2015
    Default Pajero 2.5
    Hello guys, anyone can help with stg1 Pajero 2.5 116hp
  13. #18685
    Nov 2021
    Germany
    Default Stage 1 + EGR + Flaps
    Quote Originally Posted by pedaalis View Post
    here you go
  14. The Following User Says Thank You to VollPower For This Useful Post:
    pedaalis (16th January, 2024)
  15. #18686
    Jan 2024
    Slovenija
    Good day.
    Please for stage 2 for passat b6 I have: larger injectors from ARL on BKC engine,
    larger turbine 1752v, I have a bosch pressure sensor that measures up to 4 bar.
    I will attach a folder from a car that is already on stage 1 with a larger 1749 turbo, on the folder the egr valve is turned off, and the hot start of the car is adjusted.
    Have a nice day ahead ElvisWhere can I send you my folder?
  16. #18687
    qni666's Avatar
    Mar 2019
    Bulgaria
    Quote Originally Posted by Ella2015 View Post
    Good day.
    pay to lockal tuner or hhhh i forgot is maybe your,sister,mother's car not customer car.Good luck
  17. The Following User Says Thank You to qni666 For This Useful Post:
  18. #18688
    Jan 2024
    ford focus 2.0tdci stage 1 and egr of with hardcut at 4500 please
  19. #18689
    Jan 2024
    stage 1 with egr delete and HC 4500
    ford focus 2.0tdci
  20. #18690
    Jan 2024
    hi buddy can u help me please with stage 1 egr off and hc at 4500
    ford focus 2.0tdci
