Page 255 of 1310 FirstFirst ... 1552052452502512522532542552562572582592602653053557551255 ... LastLast
Results 3,811 to 3,825 of 19649
  1. #3811
    Oct 2012
    so,you have problems...you can connect another thing on obd?...examples a diag tool?,maybe your alimentation of obd has problems...controll fuses...or,change tool for reflash...is not a problem with the original or mod files...if you can"t identiffy ecu with mpps...
  2. The Following User Says Thank You to betrescudan For This Useful Post:
    digger75 (14th March, 2016)
  3. #3812
    Sep 2014
    Somewhere
    I've conected on bench with mpps. I've writted to car, the original, thean after many tries I've read It and compared, and there is no difference. I've tried to connect vag-com and it does not connect to ecu.
  4. The Following User Says Thank You to Jashmine1983 For This Useful Post:
  5. #3813
    Oct 2012
    Quote Originally Posted by Jashmine1983 View Post
    hmmm..why on bench?...mpps is for obd connection...you maked a mistake on bench and maybe damaged ecu...vag com not comunication with all calculators,or only with ecu?...is the ecu good connected?,look the pins of connectors...verrify the fuses...and good luck...i hope you don"t bricked your ecu on bench
  6. The Following User Says Thank You to betrescudan For This Useful Post:
  7. #3814
    Sep 2014
    Somewhere
    I've conected on bench after I saw I can't connect o car. Only ECU I can't DIAG.
  8. The Following User Says Thank You to Jashmine1983 For This Useful Post:
  9. #3815
    Top Poster + denis1hr's Avatar
    Jun 2009
    near you....
    Quote Originally Posted by betrescudan View Post
    tonight will be ok?
    Can you please help me?
    I have to remove DPF because it is to change so it is better to remove it at all.
    Thanks.
  10. The Following User Says Thank You to denis1hr For This Useful Post:
  11. #3816
    Oct 2012
    Quote Originally Posted by denis1hr View Post
    Thanks.
    here your dpf fap off.......report please
  12. The Following User Says Thank You to betrescudan For This Useful Post:
  13. #3817
    Sep 2014
    Can someone modify my bmw e46 320d 150km ?
    Need more power.
    Here is original file
    Thanks !
  14. The Following User Says Thank You to hcwc For This Useful Post:
  15. #3818
    Oct 2012
    Quote Originally Posted by hcwc View Post
    Need more power.
    Thanks !
    here is your mod file....please report
  16. The Following 2 Users Say Thank You to betrescudan For This Useful Post:
    digger75 (14th March, 2016), hcwc (10th October, 2014)
  17. #3819
    mariusica_boy's Avatar
    Need more power.
    Thanks !
    here is your file mod
    please report
    Pass in PM
  18. The Following User Says Thank You to mariusica_boy For This Useful Post:
  19. #3820
    Oct 2012
    your mpps have not the reccovery option?...use it on bench on slow mode...it can wake up your ecu...and do not make others mistakes..you can use reccovery to write the mod file like being original
  20. The Following 2 Users Say Thank You to betrescudan For This Useful Post:
    diagprog (9th October, 2014), digger75 (14th March, 2016)
  21. #3821
    Junior Member Myago's Avatar
    Italy - Bergamo
    I need dpf off with working cruise for my Honda 2.2 Civic
  22. The Following User Says Thank You to Myago For This Useful Post:
  23. #3822
    Oct 2013
    Default peugeot 807 2.2 hdi
    i need a tuning filr for my Peugeot 807 2.2 hdi 2004. Can somebody help me..?
    ThanksAttachment 281002
  24. The Following User Says Thank You to clio1234 For This Useful Post:
  25. #3823
    Oct 2012
    Quote Originally Posted by clio1234 View Post
    nice car....yum-yum
  26. The Following User Says Thank You to betrescudan For This Useful Post:
  27. #3824
    Mar 2014
    Default egr off visteon tranzit 2.4 tdci 2007
    hi to all
    pls egr off...and dtc off
    hi to all
    pls solution egr off and dtc off...FORD TRANSIT 2.4 TDCI 2007 ENGINE H9FB...VISTEON DCU102
    THANKS IN ADVANCED
    ford trazit 2.4 tdci...2007...ecu :visteonDCU102 MOTOR H9FB
    thanks in advanced
  28. The Following User Says Thank You to zoranmadzar For This Useful Post:
  29. #3825
    hello i got peugeot 307sw 2008 benzin - can it be more fuel saving?
  30. The Following User Says Thank You to totalkey For This Useful Post:
