SonyPS3 (2nd February, 2019)
Andytech3 (2nd February, 2019)
Hello, you could make me a Flaps Off for this Ecu, Audi A6 3.0 BMK EDC16 + CP34
SW 1037372486 4F0910401L DTC P3199
A6 3.0 TDI.Ori.rar
Please map my file ....THANKS
Thank you MagnetoCar, it is noticeably better, the onset of power at about 1800 - 2000rpm, but can not the engine add a piece more? Even at the expense of engine life?
Can you change my file, Citroen C5 X7 163HP Delphi DCM3.5 2010, automatic transmission
I care about:
- disable FAP
- raising the power to 180HP - if possible
- change minimum RPM on 6th gear - I would like it to be 1800RPM - if possible
Thank you in advance for your help.
i wonder if anyone can modify this file for more performance?
its from a peugeot 206 cc 2 litre 16 valve.
i realise its a long shot as it naturally aspirated and the car is 14 years old.
thank you in advance.
I would like if possible MOD STAGE1
Citroen c4 1.6HDI 90cv?
0281011863
EDC16C34
9661773380
9653958980
1845 4092
06/09/18
1039S12134
Car is running well but a bit poor.
Use is 80% highway
Really thanks beforehand.
In fact, I hope it becomes the day when I can help you in the same way
GolfmkI (4th February, 2019)
Hi ! Somebody can make me stage1 For Ford focus 2.0 tdci SID803A. Already i got 5 version none works i can send those too if somebody interested in
Is it possible to remove the EGR from the software?
Audi A3 2005 2.0 FSI
ECU : MED9.5.10
If you need more information please ask.
I have made a dump file of the ecu which i've added in this post.
If someone could remove it for me, that would be great
When it is not possible or really hard to do, please also let me know, then i know where i'm up to
Already many thanks for your help![]()
Hi, I need Immo Off for the BMW 320D 2001 BOSCH 0 281 010 205
EEPROM 24C04
thank
Good evening, delete egr from the Suzuki swift 1.3mjet 70hp file THANKS Paul
