Page 736 of 1311 FirstFirst ... 2366366867267317327337347357367377387397407417467868361236 ... LastLast
Results 11,026 to 11,040 of 19652
  1. #11026
    Default audi a5 177hp manual stage 1 03L906018JG 9978
    hi anyone please tunig stage 1 egr delete my audi a5 177hp 2012 soft 03L906018JG 9978 ,many thanks
  2. #11027
    May 2019
    Default stage 2 1.8T 20vt
    hello can you retouch a map stage 2 and lambda off
    thank you so much
    audi tt 1.8t 20vt BAM
  3. #11028
    Feb 2013
    Bulgaria
    Quote Originally Posted by david80470 View Post
    thank you so much
    This is file Lambda OFF, but not tune stage2
    pass pm
  4. The Following User Says Thank You to pena For This Useful Post:
    david80470 (5th May, 2019)
  5. #11029
    May 2019
    great thanks for the speed
    stage 2 is not possible?
  6. #11030
    Feb 2013
    Bulgaria
    It is possible, but I have explained in the previous posts why I will no longer do tuning files.
  7. The Following User Says Thank You to pena For This Useful Post:
  8. #11031
    May 2019
    possible en stage 1 ?
  9. #11032
    May 2019
    Default stage 1.8T 20vt
    it's possible to put more turbo power I will want 1.5 merci
  10. #11033
    Member alfainyeccion's Avatar
    republica Argentina
    hola amigo puedes eliminar dtc p0420 desde ya muy agradecido
  11. #11034
    Sep 2018
    hi , can you remap my 2003 Kangoo DCi 1.5 82hp? egr off and some extra torque and power.
  12. #11035
    Jul 2018
    Default bmw e46 110 kw
    hello need tunap this files.
  13. #11036
    Feb 2019
    Hi all,
    please help stage1 remap from Skoda Octavie 1.9TDI 81kw.
    Thanks you.
  14. #11037
    Mar 2019
    Default mk2 swap
    My setup.1.8 20vt aqx ( seat ibiza cupra )K04 turboForge blow ofBig tipBam intake manifoldBig front mount intercooler Pipercross open airfilterBosch 380cc injectors6 bar extended feul pump4 bar fuel regulator valveHigh flow exhaust manifold3 inch downpipe + exhaust ( no cat ) - g60 gearbox- The calibration is now based on stage 1..original aqx. Cat - egr immo and al the other crap is already earsed on ecu.
    can u calibrate the feul en boost and anything
  15. #11038
    Feb 2013
    Bulgaria
    Quote Originally Posted by Andrew125 View Post
    Could I get my 1.3 Corsa 75HP remapped?
    In original file, i found some anomaly. Maybe a download problem, but it will show up, when upload tuning file.
    This is your file
    pass pm
  16. #11039
    Ignasvw's Avatar
    Feb 2016
    Lithuania
    Default stage1++
    Quote Originally Posted by edoh84 View Post
    pass in pm.
    tool will fix checksum
    Chiptunning / EGR / DPF / FAP / DTC / FLAPS / Adblue / ETC.... CUSTOM SERVICE / FILE SERVICE / 24/7 Support
  17. #11040
    Ignasvw's Avatar
    Feb 2016
    Lithuania
    Quote Originally Posted by johncz View Post
    Hi all,
    Thanks you.
    Here stage1
  18. The Following User Says Thank You to Ignasvw For This Useful Post:
    johncz (5th May, 2019)
