Hi. Please help egr off and P2111 off Peugeot Boxer 3.0 hdi ecu bosch 0281 018 291 THANKS
marszalek1 (20th August, 2019)
I need to activate cruise control on Isuzu Dmax TD 3000 4JJ1 Engine
I used Kess v2 clone to get the file from Transtron ECM
Please help
ID :
HW: TTI 0100
SW: 98341285
VIN nr.: MPAER33T4JT007771
SW ver.:
Spare:
Engine:
HW Ver.:
SW upg.:
Installation: 4JJ1
a500tut
Hi brother.
i have a nissan xtrail 2.2 dci 2006.On the OBD socket it has as communication protocol the kwp2000.I took the two CAN lines of the internal bus between the units; ABS, A / C, Dashboard ... and I made a connection to the OBD socket, so I could read my ECU via OBD with Kess V2.
So after all this work, I want to test two options(files), an EGR off, and an EGR off + tuning to optimize consumption.So please can you prepare these two modified files for me? here is the original file :X-trail 2.2DCI DENSO SH7058 HW E30FU4D_ SW T281ZR05.rar
Please remove the egr
car: seat leon 1.8 20vt
https://filebin.net/2j2k7h0smjpuhn7a...eon?t=6s2ryt37
James83 (21st August, 2019)
Hello masters! Please, Would anyone make a stage 1 map for Passat B6 2.0 TDI 140HP from 2007?
Thanks in advance.
lookerman (23rd August, 2019)
I have opel astra convert , I search flexfuel e85 remap for this, thanks
Anyone able to do me this tune? Thanks
Links here for the stage 1 details (https://bit.ly/2TUcpan)
Good morning everyone, bought a pagero io 1.8 gasoline I thought half weak I would like to know, if there is an up on the map ... and switch to alcohol, has automatic exchange, Li ecu by KtagMr420493.rar
I need some help please. I appreciate the help. bmw 520 ,2007,163cv more power and dpf ,egr off ,
Hello help, need more power do what you think best, often in limp mode, new engine and all sensors.
Viewing oil and temperature map is maybe a problem. If you do not find a problem to eliminate error 30C1, block it.
I am using KESS V2
My car BMW 320i E92 04.2008 170bhp, engine N43B20
HW: 07599881
SW: 07618282
VIN nr.: WBAWA72060PZ62966
hello,I need edit start iq or SOI map when car is hot it is problem crank engine (P0340). Thanks for reply
