Hello I would like to have more power, cut limiter, egr off, dpf off. Mercedes sportcoupe 143hp 220cdi. 2003
HI! can anyone tune this file? Thanks a lot!
its BMW e39 530d 193hp with automatic transmission.
Can you fix stage 1 + egr off
Caddy 1.9 TDI
Engine: BLS
Gerarbox: Automatic
EDC16U34 - 03G906021AR
I use MPPS
Originally Posted by lookerman
Hi brother.
i have a nissan xtrail 2.2 dci 2007.On the OBD socket it has as communication protocol the kwp2000.I took the two CAN line of the internal bus between the units; ABS, A / C, Dashboard ... and I made a connection to the OBD socket, so I could read my ECU via OBD with Kess V2.
So after all this work, I want to test two options(files), an EGR off, and an EGR off + tuning to optimize consumption.So please can you prepare these two modified files for me? here is the original file :X-trail 2.2DCI DENSO SH7058 HW E30FU4D_ SW T281ZR05.rar
Sure! Password in pm!
thanks brother...i corrected the cheksum & i flashed the file ...now i'm testing...i will report if the P0404 apears again ...thanks again
here are orginal firl from passat 1.9tdi 4 motion 6 gears manual..
looking for max performance... all they way up to max egr.dpf lauch what ever you can put into it..
the car are going to be scraPPED because of frame bent.. but what to try to tune it to the max and have some fun before we deliver
it to become nails.
and if the perfomance are super ..as i hope i will of coruse take out the ecu before trowing it..
if anyone can make me a professional max power file... i can promisse to return video of the "testing" of the new ecu file...
hello all this is the original file I need. it is just a bad file installed ... can someone help? I would like to stage 1 and pops and bangs over 3500 revolutions. I speak German, my English is bad. translator helps. may someone help to create this file, I myself do not understand it all.
politex3 (27th August, 2019)
Daves38l (25th August, 2019)
Need cat off for bmw e46 318i m43tub19 Bosch bms46
Thanks in advance
Attached orgi file
Hi guy i have send my ecu file for you remap! thank
Thanks i will test it.
VW Golf V GTI
need on my e60 523i lci 190hp,
euro2 ( NOX and second lambda off)
stage1
Hi there. I'd like Stage 1 + popcorn if available.
Thank you :-)
BMW E39 530D 142KW 194HP Originalas.rar
