BMW F10 530Dx 258hp
EDC17C50
EGR off please
BMW F10 530Dx 258hp
EDC17C50
EGR off please
Hello, i need your help. I have a Ford Transit 3.2tdci with egr mechanically turned off, so i have check engine.
Could you help me with removing the problems with my car's map?
1. egr off
2. gear 1,2,3,4 - removal of the power limitation (in 5,6 gear it has more power and torque) + chiptuning
3. change the drive bridge ratio in the map. It is 3.58 and should be 4.27 (the engine is after swap, previously it was 2.4TDCi)
thanks guys if it possible make from old mobile power
Hi. I need to make an optimal map for this car. Will somebody take on? Of course, I'll pay for a good mod.
BMW 535 LCI 2008r Aut.
HW ID: 08509036
SW ID: 07797506
HW NR: 0281015241
SW NR: 1037500776
EDC16CP35/C
Hello) Anyone help me to make stage 1 on opel corsa D 1.3cdti
355568383
33333S362
Please
Stage 1
EGR OFF
DPF OFF
Can I set DEUTZ EDC17CV52 Stage1
Help
Thank you
can someone remap stage 1 for citroen c5 edc16c34
thanks a lot
Please,can i have this file ?thank you
Hi guys
Im just checking to see if any of the below is possible with the map file I pulled from a Astra G y17dt, im still in the process of learning and would like to compare the modified files with the original.
Smoke Map
Popcorn Limiter
More Power, but safe map wise
Thanks guys
guys, can somebody do stage 1 tune for my audi a3 8l,
1.9 tdi 2002.
edc15+ 96kW,
engine type is ASZ,
0281010981,
038906019FT
