please i need dpf\egr off in simos 306
dacia duster 1.5DCI110HP hw 0764R sw 1469R
is possible??
thanks advanced!
is possible??
thanks advanced!
Hello,need hot start fix for ford galaxy 2002 1,9 tdi 115 hp,EDC15P,thanks
TUNING--FILE SERVICE--VMAX--EGR--DPF--FLAPS--LAMBDA--DTC--IMMO..........POSSIBILITIES ARE ENDLESS
SPECIALISE IN TUNING DIESEL ENGINES
(DEMON DEVELOPMENT)
IF I HELPED YOU DONT FORGET TO HIT THANKS AND REP POSSIBILITIES ARE ENDLESS
Hi, is it possible to have Stage 1 and EGR delete please?
Please find my original file attached.
Nissan Patrol 3.0 ZD30 CRD
EDC16C41
ECU: 0 281 014 154
SW: 1037392203
Many thanks!
207 1.6 THP stock engine Stage 1
i have EIS w203 , 209 , not work , i have read it with VVDI , i think the Dump corrupted , please can you help me ?
Hi All
I Want to have EGR ON for a Winter. Please do it for me.
e46 2.0D 150KM - with virus 200KM
I wanted to thank you again.I have tested the car 500km.It has not presented any fault in the panel, or in the switchboard.The only thing that the problem persists, but it is not a problem with the file, because with the original it does too.I think it is a problem of injectors or connectors of injectors.I wanted to ask you a question.Does the car have more power?I have not driven fast to test everything and that it will settle everything well.If I have noticed better acceleration thanks to canceling the flaps.The egr no longer reports the error P0403.Thank you very much I really appreciate it very much.
Here you have it.
BongoGER (28th January, 2021)
Hello i read with fvdi this flash i need stage 1 + checksum correct
tnx and appreciate
ecu info:
A 026 545 26 32
BOSCH 0 281 001 884
K02 ED0024 CR1.6 2.21 4ZylFD 99M01
hw/sw 42.98
Hello,need stage I and egr off for this vehicle,thanks
