Page 900 of 1259 FirstFirst ... 4008008508908958968978988999009019029039049059109501000 ... LastLast
Results 13,486 to 13,500 of 18883
  1. #13486
    DK Veteran brad123's Avatar
    Dec 2011
    France
    Quote Originally Posted by WOODWARD395 View Post
    Hi when an EGR delete is done and the EGR is left on site, has the vacuum pipe got to be clamped blocked off or do mappers stop the vacuum to EGR.
    i also have a very high reading on my MAF sensor approx 450 mg when has always been around 270 mg been told its the mapping is anyone willing to have a look for me please as mileage has dropped down as well thanks.
    is it possible to do complete EGR Delete and EGR as it is if possible giving me two maps as may be removing EGR for better results if possible MAP seems fine otherwise thanks.
    Pass PM
    Remap (stage 1) / DPF / EGR / SRC/AdBlue / DTC off / VSA/Intake/Swirl flaps off / Lambda/O2 Removal/LSU / Start-Stop disable / Speed limit remove...
  2. #13487
    Sep 2019
    vietnam
    Default Help OFF ERG hyundai trago 2012 DELPHI
    Trợ giúp TẮT ERG hy sinh trago 2012 DELPHI
  3. #13488
    Mar 2020
    Hi. Can someone check ori file and make stage 1?
    VW T5 1.9TDI BRS
    SW: 1037393510
    Engine: R4 1,9L ED
    SW upg.: 038906016AL 2249
  4. #13489
    Oct 2019
    Default MB Vito 109 Cdi 95Hp
    Can someone offer a good stage1 (170hp+) for MB Vito 109 CDI W639 95hp ?
    SW: 1037383369
    Spare: CR40-64x-70T2-639-070kW-43O-0MEF-02-RFV-001_ME1
  5. #13490
    Junkyard Dog's Avatar
    Mar 2019
    EUROPE
    Quote Originally Posted by trabirider View Post
    SW: 1037383369
    PASS IN PM
    THANKS + REP
    TRY AND REPORT!
  6. #13491
    Mar 2020
    Hi. Again me with map to VW T5 1.9TDI
    Can someone make stage 1?
  7. #13492
    Jul 2018
    hi, please egr off my citroen berlingo 2.0hdi siemens sid 801a
  8. #13493
    Baddog84's Avatar
    Sep 2012
    Germany
    here is your tuning file
    Quote Originally Posted by erqa View Post
    WinOLS 5, FGtech, Piasini, Powergate M, Byteshooter, OptiCan Dual II, EVC BDM, VCDS, BeeProg+,Ktag, Kess V3, Autotuner, Bflash
    Fileservice
    no thanks no pass
  9. The Following User Says Thank You to Baddog84 For This Useful Post:
    erqa (1st June, 2020)
  10. #13494
    Mar 2020
    Quote Originally Posted by Baddog84 View Post
    What about Pass?
  11. #13495
    Apr 2020
    Quote Originally Posted by freedoom View Post
    try this, pass PM
  12. The Following User Says Thank You to ZiZiTun For This Useful Post:
    freedoom (1st June, 2020)
  13. #13496
    calibracbr's Avatar
    Aug 2015
    Moon
    Please need good working solution for dpf off bmw e90 318d edc17c41 ecu
  14. #13497
    Member zirveelektronik's Avatar
    Apr 2019
    İstanbul
    hi i need stage 1 skoda octavia 2012 1.6 tdi
    ecu: pcr 2.1
  15. #13498
    Baddog84's Avatar
    Sep 2012
    Germany
    here is your file
    chks ok
    Quote Originally Posted by zirveelektronik View Post
    ecu: pcr 2.1
    Fileservice
    no thanks no pass
  16. #13499
    Dec 2019
    slimme roadster 60kw?
  17. #13500
    Apr 2020
    Quote Originally Posted by zivcani2017 View Post
    Hi. I need dpf off. Can someone help?
    edc17cp14 the car already has stage 2.
    Attachment 718224
    4 Faults Found:
    4914 - Diesel Particle Filter; Differential Pressure Sensor
    P2453 00 [032] - Implausible Signal
    8669 - Sensor 1 for Exhaust Temp Bank 1 (G235)
    P0544 00 [237] - Circuit Malfunction
    5182 - Particulate Trap Bank 1
    P2002 00 [237] - Efficiency Below Threshold
    5188 - Diesel Particle Filter
    P2463 00 [175] - Excessive Soot Accumulation
    Thanx
    pass PM, stage 2 + dpf
  18. The Following User Says Thank You to ZiZiTun For This Useful Post:
    zivcani2017 (3rd June, 2020)
