Page 1 of 30 12345611 ... LastLast
Results 1 to 15 of 444
    Default VAG-COM/VCDS LATEST DUMPS
    Please use this thread only for posting working vcds dumps.
    Attached 908 working atmega & ftdi dump.
    Use thanks if it was useful
  2. The Following 39 Users Say Thank You to betonel For This Useful Post:
    ABD ERRAHMANE (22nd June, 2014), abdomm (13th April, 2016), adygopo (18th August, 2016), alex64 (14th November, 2018), Azorath (11th March, 2023), bolke322 (14th January, 2023), bsman1985 (5th January, 2016), Col19 (20th December, 2019), djalil (12th February, 2019), ecumanager (25th October, 2015), erd11 (2nd December, 2021), erdi19 (2nd December, 2021), f5223521 (9th October, 2018), fluorescent (10th June, 2016), gebooss (2nd May, 2018), hendriono (31st October, 2017), jnoroeste (20th September, 2015), Jonnybgud (4th March, 2018), kadi0209 (15th August, 2014), KennySmit (28th April, 2016), luizdoval (29th April, 2020), madbg (2nd May, 2014), morran (8th January, 2018), Mrjitter (11th January, 2017), mvtonline (23rd February, 2025), naser (18th August, 2013), Papiti56 (24th August, 2024), Rebello Brian (12th August, 2020), roby65 (27th July, 2022), sahnoun363 (11th June, 2015), semga (8th October, 2015), sep382 (7th April, 2017), tinchokapo (31st March, 2016), tobyas (2nd September, 2020), toto11 (1st December, 2016), Touwa292 (27th March, 2017), VWfan (13th January, 2019), wheelman (25th December, 2015), youssef70 (11th November, 2014)
  3. #2
    Default VCDS_11.2.0
    Working dumps for 11.2. FTDI 232BM
  4. The Following 13 Users Say Thank You to betonel For This Useful Post:
    ABD ERRAHMANE (22nd June, 2014), bolke322 (14th January, 2023), ecumanager (25th October, 2015), hansebaenger (14th March, 2020), hendriono (31st October, 2017), jesyblue13 (25th November, 2021), Jonnybgud (4th March, 2018), naser (18th August, 2013), rkd (10th July, 2020), seal777 (9th April, 2021), semga (8th October, 2015), VWfan (13th January, 2019), wheelman (25th December, 2015)
  5. #3
    Default VCDS_11.2.0
    FTDI 232RL ept file. I use UPA usb, first write flash, then eprom to atmega162. Last step check lock bits and fuse bits.
    Write FTDI 232RL with mprog 3.5.
  6. The Following 16 Users Say Thank You to betonel For This Useful Post:
    bolke322 (14th January, 2023), ChrisVonHertz (3rd September, 2020), Col19 (13th November, 2019), darka7 (1st March, 2017), ecumanager (25th October, 2015), estwood68 (23rd October, 2021), hendriono (31st October, 2017), Jonnybgud (4th March, 2018), mexanico1971 (30th March, 2013), milerk (1st April, 2017), naser (18th August, 2013), sinclocker (9th January, 2018), tyrystor (10th July, 2021), wheelman (25th December, 2015), xifly18 (17th May, 2017), Zharoff (14th December, 2015)
  7. #4
    More files..
  8. The Following 20 Users Say Thank You to betonel For This Useful Post:
    bolke322 (14th January, 2023), Col19 (13th November, 2019), ecumanager (25th October, 2015), eeautomotiva (12th March, 2017), hendriono (31st October, 2017), jnoroeste (20th September, 2015), king1830 (21st December, 2017), milerk (1st April, 2017), Mrjitter (11th January, 2017), naser (18th August, 2013), Noetzel (10th March, 2016), Papiti56 (24th August, 2024), PEROVSKIGSM (21st September, 2016), semga (8th October, 2015), sinclocker (9th January, 2018), tinchokapo (31st March, 2016), tyrystor (10th July, 2021), velisav (8th November, 2024), wheelman (25th December, 2015)
  9. #5
    Default VCDS_11.2.0
    Tested on chinese cable 912.
  10. The Following 18 Users Say Thank You to betonel For This Useful Post:
    alexroma85 (9th November, 2017), alyvo (1st February, 2017), bolke322 (14th January, 2023), coolk0415 (31st March, 2016), cosmin12345 (17th April, 2017), ecumanager (25th October, 2015), eeautomotiva (12th March, 2017), estwood68 (15th December, 2021), hbalazs (22nd January, 2017), Headelux (7th August, 2024), hendriono (31st October, 2017), johnnygumbo (18th July, 2019), milerk (1st April, 2017), naser (18th August, 2013), Noetzel (10th March, 2016), sarigol45 (18th November, 2013), tyrystor (10th July, 2021), willie765 (20th April, 2016)
  11. #6
    This interface with FTDI 232RL chip I have tested.
    USB VID=0403
    USB PID=FA24
    Atmega + FTDI program that's all for this hardware.
  12. The Following 4 Users Say Thank You to betonel For This Useful Post:
    coolk0415 (4th April, 2016), ecumanager (25th October, 2015), Headelux (7th August, 2024), naser (18th August, 2013)
  13. #7
    DK Veteran kelekele's Avatar
    Sonta,Serbia
    What about this hardware vcds 10.6.Is it possible repair this interface:
  14. The Following 2 Users Say Thank You to kelekele For This Useful Post:
    naser (18th August, 2013), pintobraz (8th August, 2014)
  15. #8
    possible, but not really recommended - ft232RL, transistors/comparators instead of L9637 or another driver for k-line... it's a cheap and bad adapter. usually it's not worth the effort.
  16. #9
    POLAND
    great post betonel
  17. #10
    bursuc's Avatar
    Oct 2011
    inside MCU
    Hy to all.... i got one VCDS 9.08 , the problem i have :
    The LED's are not working at all...i reflash the processor and eeprom but still no leds come's up.
    I found one transistor shorted, i take it out .
    It was the transistor from K-line... i pun another one from L-line...but still nothing...somebody a sollultion ?
    Thanx
    Dosen't matter how hard is to repair something as long is made by humans and thinked by humans !
  18. #11
    Member ph0en1x's Avatar
    Serbia for now
    Quote Originally Posted by bursuc View Post
    Thanx
    Led is not working if your 7085 regulator not working (check +5V) or atmel is empty.
  19. #12
    bursuc's Avatar
    Oct 2011
    inside MCU
    i got 5 v , right now i am connecting upa to see if atmel is empty or not . i think in the past i read only eeprom from atmel and seems to be ok , i will read full flash now to check it . thank you
  20. #13
    matekhr's Avatar
    Croatia
    UPA won't help you testing is Atmel empty or not, because it is locked. Take dumps from this thread and re-program your Atmel as decribed here.
  21. #14
    bursuc's Avatar
    Oct 2011
    inside MCU
    still no LED's , i write the dumps, thee eeprom snd the flash on atmega, but still the LEDS are not powering up ... 7805 is working....any other ideas?
  22. #15
    Maybe led defective or wrong soldered? Power and/or ground on obd connector?
