Page 10 of 30 FirstFirst ... 5678910111213141520 ... LastLast
Results 136 to 150 of 444
  1. #136
    Mar 2016
    Regards to you.
    question: Are there any dump files for VC 11.11.3?
  2. The Following User Says Thank You to pantarei For This Useful Post:
    boomfunk (23rd July, 2020)
  3. #137
    gopelhu's Avatar
    EU
    Hi all,
    I share my other solution for vcds 12.12.x.
    Today I created the ATmega162 dump and works perfectly 100% !!!
    Step-by-step:
    Pls install only this installer: VCDS-Release-12.12.0-Installer English 512bits.exe !!!!
    When you installed, pls upload the ftdi232rl.ept file to the FTDI FL232RL ! Important !!!
    This solution works with vcds interface that's has a FT232RL ic.
    After rund the vcds 12.12.0 exe and pls go to options and pls push the test button, after save it.
    This self-learning solution !!!
    https://mega.nz/#!rI1jwJ5Z!8uTzANKm7...qlRR488xZha6O8
    ENJOY !!!!
    Regards, G
  4. The Following 6 Users Say Thank You to gopelhu For This Useful Post:
    Menber (25th February, 2017), Mrjitter (13th January, 2017), n599fbm (8th May, 2016), RogerioAndrade (10th March, 2017), Thundr4 (17th December, 2022), vanos batam (26th April, 2016)
  5. #138
    Long coding works?
  6. #139
    Oct 2011
    Quote Originally Posted by gopelhu View Post
    Hi all,
    Step-by-step:
    ENJOY !!!!
    Regards, G
    Thanks it's work with my interface. I test a scan and an erase of error, perfect.
  7. The Following User Says Thank You to JBLSteeve For This Useful Post:
    gopelhu (14th March, 2016)
  8. #140
    Hi all,
    Step-by-step:
    ENJOY !!!!
    Regards, G
    Any solution for FT232BL/BM?
  9. #141
    gopelhu's Avatar
    EU
    sorry but i dont have more free times, maybe weekend
  10. #142
    fantomel's Avatar
    Mar 2009
    Us
    Nice to see the dumps i shared here after so long time.
    That 12.12.0 it's not working on long coding and adaptation, but same dumps works also on 11.11.5 that i posted in other forums for free for all.
    If you like my post and it helped you please press THANKS.
  11. The Following 5 Users Say Thank You to fantomel For This Useful Post:
    gopelhu (16th March, 2016), millencolin (10th July, 2016), paro44 (17th March, 2016), teamtuner (16th March, 2016), vanos batam (26th April, 2016)
  12. #143
    can you help me how to update my vag 11.11. to 12.12
    thanks to all
    best regards
  13. #144
    I have tested FT232BL/BM V12.12.0 and V11.11.5 posted by Fantomel but most of the time doing logs connection last some seconds only. I have test 2 cables with same problem. Do you know what can cause this problem?
  14. #145
    gopelhu's Avatar
    EU
    Quote Originally Posted by eliotroyano View Post
    The FT232BL/BM differents content wit FT232RL, pls do not try it.
    I will create the content to FT232BL/BM, pls wait untill i will finished and tested it/them.
    Regards, G
  15. The Following User Says Thank You to gopelhu For This Useful Post:
    PEDRO4053 (15th June, 2024)
  16. #146
    gopelhu's Avatar
    EU
    Quote Originally Posted by abdelamjid View Post
    thanks to all
    best regards
    Hi, pls upload your interface pcb top and botton sides.
    Regards, G
  17. #147
    Regards, G
    Ok great!!!!!
  18. #148
    gopelhu's Avatar
    EU
    again i upload bec i lost my pc
  19. The Following 6 Users Say Thank You to gopelhu For This Useful Post:
    Col19 (13th November, 2019), DeVito (10th July, 2017), kiyrik (22nd May, 2016), RogerioAndrade (10th March, 2017), tyrystor (10th July, 2021)
  20. #149
    Feb 2013
    It is not clear, this is for FTDI BM/BL?
    thanks for you work and time!
  21. #150
    Nov 2012
    Croatia
    Quote Originally Posted by alexm1 View Post
    RL as i see
