Page 15 of 30 FirstFirst ... 5101112131415161718192025 ... LastLast
Results 211 to 225 of 444
  1. #211
    Aug 2016
    I have VCDS 15.7.3 with FW 1.94 with no licence. I think by mistake connected to the internet and now . Can somebody help me with this?
    Thank you in advance
  2. #212
    Oct 2008
    On Earth
    I don't think that anyone can help you flashing your tool
    we don't know what tool did you used BL or RLbut I'm very sure its RL
    this mean that the chip Id it must be marriages with the ft I Id and if you didn't extract your dump before then I don't think th at someone can help you
    much more of this who do you think that it spend time to extract Chinese ~~~~ tools dumps?
    Because is there no reason this tools has no future. The clnd serial will be blacklisted and the cracked CDs has no internet protection
    you can find a good dump and software in Mr.Fantomel collection the 11.11.5 vcdsversion and you can flash it and use it
    But please share two pics with your both sides of PCB of your tool
    let us know what kind of tool you have
    Good luck
  3. #213
    Aug 2016
    I'd like to buy a chinese clone obdII connector. Which one can you recommend?
    Therefore I want to flash a dump of an original dongle to the chinese interface?
    Is it possible?
    Thanks in advance
  4. #214
    Aug 2016
    I have ATMEGA 162 and FT232BL. I need to make this interface working for a Touareg 2013. Any ideas?
    I did not tried to do any flash to this interface. Just used with internet on and now in blacklisted, I think. I receive error not Licensed. This has been already updated from ver 11 to 15.7.3 by the guy who sold me this interface.
    Thank you in advance.
    14215372_1094641753916719_1287625154_o.jpg 14194238_1094641070583454_862859254_n.jpg
  5. #215
    Aug 2016
    As an addition to my previous post, I'd like to know, which configuration is the latest one which is working perfectly?
    Which Dongle do I have to buy, and which software do I need?
  6. #216
    Sep 2016
    I want to buy chinese dongle. There are some with 15.7.1 software. Is there some hardware differences? Where can I find the schematics?
  7. #217
    Oct 2008
    On Earth
    Any hardware that contain Atmega, GAL/ATF, FTDI, MCP and L9637D ( on k-line ) or tranzistors .
    Noone cannot say wich has more quallity then other but all can be good.
    Now about the software used and the chinese solutions I will advise you buy any.
    Because chinese do n ot make:
    - solutions that can be upgraded
    - solution that has internet protections or similar solutions that will not let ross-tech servers to erase you license
    And in this case you never know when you will not be able to use your tool because UNREGISTRED
    Now about original dump
    So in any of the chinese tools that contain Atmega you can flash a genuine dump
    If you has a RL tool you need a loader that will pass the FTDI ID check
    If you have a BL one you need a loader to pass the FTDI ID check
    or you need a dump from a genuine tool with BM
    But in all of this cases you need to stay away from internet no matter taht you will use the internet only when the tool is not plugged. In any moment when you have the internet connection turned on your vcds license is checked by ross-tech servers
    In all of this cases the loader must pass the FTDI ID check and block the internet connection of vcds
    In case that you will be "cach" you will not loose only the clone but you also will loose the genuine one
    I do not advise you to do this
    Good luck
  8. The Following User Says Thank You to mattydr67 For This Useful Post:
    paro44 (7th September, 2016)
  9. #218
    Sep 2016
    Hi Mattydr67,
    thanks for the explanation.
    What for is the GAL? are all device version have same GAL program?
    So, I will order the one with 15.7.1 software and try it.
  10. #219
    Oct 2008
    On Earth
    GAL/ATF is for Dual K-line cars
    with other words CDs can connect in car with dual k-line
    official vas5054 needs to add an adaptors vas6017 to be able to connect in this cars
    GAL is an electronic switch for K1 and k2 lines
    As I know all GAL has the same dump
    What you exaclly want to try? To flash a clone with original dump?
    Good luck
  11. #220
    Sep 2016
    i have vcds 12 and was working good until i got error message sorry this function requires a lenience i don't know what is the atmega is it tool or program or where i can buy it is there any software can help ??
  12. #221
    Sep 2016
    Quote Originally Posted by heshamzn View Post
    I am with the same problema. My release is 12.12.0. Can someone help?
  13. #222
    Oct 2008
    On Earth
    Guys without dumps this will cannot be fix it
    Search and you find free dumps in the forum and reflash your tools
    Otherwise will never work
    Your tool is already erased. Unregistred
    Or try to find a HQ clone and you never have a problems like this
    But the HQ clone is 3-4 times expencive then a chinese clone but you can upgrade it as you upgrade a genuine one
    Good luck
  14. #223
    Sep 2016
    thanks for the help!
  15. #224
    Oct 2008
    On Earth
    I didn't helped you.
    I just advised you.
    In the rest its your choise
    Mr. Fantomel collection contain what you need dumps and software and how to flash your tool. Only that you need it more is an external AVR programmer
    Good luck
  16. #225
    Aug 2016
    Quote Originally Posted by mattydr67 View Post
    Good luck
    Where can I find a HQ clone?
