Page 19 of 30 FirstFirst ... 9141516171819202122232429 ... LastLast
Results 271 to 285 of 444
  1. #271
    Oct 2008
    On Earth
    This is not a general solution
    Each one can make his solution
    I haven't seen newer solution then 11.11.5/12.12.0 shared in public ( use google )
    The good solution you will not find in China or in public web shops or sold in forums in market place
    This solution will be killed sooner or later
    Flash = reprogramming - search how to reprogram VCDS in forum you will get what you need
    Good luck
  2. #272
    Feb 2013
    There is a way to see if a cable has inside Atmega or NEC without open it? Any software to "read" via usb?
  3. #273
    Oct 2008
    On Earth
    There is way to tead and write the MCU ny Usb w/o Open it.
    But you cannot see if uts Atmega or NEC.
    I had a dump extracted from a clone w/ NEC and I flash it in a clone w/ Atmega.
    Just to check if this one are diffrent
    Good luck
  4. The Following User Says Thank You to mattydr67 For This Useful Post:
    alexm1 (23rd January, 2017)
  5. #274
    Feb 2013
    Ok, I got it, it is not possible...
    I had to know that, in case I buy a new one and will be with "waranty" seal...I will not know if it has Atmega or NEC.
  6. #275
    Feb 2017
    Default Cracked VCDS 16.8.0
    Cracked VCDS 16.8.0 (Exe only) and ATMega dump (FW for HW type 1 & 2 + EEPROM). Dissabled marriage with FTDI Chip ID and cleared blacklisted serials. Original VCDS 16.8.0 installation can be found here https://link-4share.com/download/jl3...aller_rar.html.
    Copy cracked VCDS vcds_dump_16.8.0_crack.exe to the directory where vcds is installed and run it.
    vcds_16_8_0_cracked_plus_atmega_dump.zip
  7. The Following 14 Users Say Thank You to kolimer For This Useful Post:
    alin 151 (22nd March, 2017), alyvo (1st February, 2017), busterxxx (2nd February, 2017), cocutanu (9th April, 2017), Col19 (13th November, 2019), ghicicine (12th March, 2017), hartklep (3rd March, 2017), hotkar (13th March, 2017), kisslorand (5th February, 2017), korfi (29th June, 2019), lupu_sandu (4th February, 2017), Nike (6th March, 2017), RogerioAndrade (5th June, 2017), viking6791 (17th February, 2017)
  8. #276
    Quote Originally Posted by kolimer View Post
    Hi Man!
    Sorry for my ignorance....
    Can you show pictures of those different HW?
    What are the differences between them?
    regards
  9. #277
    speedy100's Avatar
    Athens
    Default Super 812.4 upgrade ?
    I have cable Super 812.4 Dual K&CAN and would like to upgrade it to newer software. It now runs VCDS 805 as ver. 812.4 was a Beta ver. and did not run good...
    I read all posts here but did not see anything about this specific cable.
    Is it possible to upgrade it and if so any d/l links and info on how to?
    Thank You and Best Regards
    Knowledge is to share... so if I have helped just press [Thank You + Rep.]...
  10. #278
    Feb 2017
    HW1 - ATMega pins 34 and 35 connected to GAL
    HW2 - no connection on ATMega pins 34 and 35
    EEPROM is the same as for 11.2, but blacklisted serials are cleared from vcds.exe. Also signature checking (RSA) of license is disabled.
    EEPROM addresses :
    - License : 0x00B0..0x00BF
    - RSA signature (SHA1 of License) : 0x0041..0x00AE
    RSA Public KEY N : 5752669A8452A1C46E597E645B8674F2CAF6A6E2E51404FF28 A3DABD422B44DFD036D3D85E4BAD308F4185EAC05E8FEA6E0D 505CF22896DD76FFCDBC11708AF765D0991F1747262BA9ED8B EEDE83E36CC1FF535179BF43AD26CB76CB073BD3CA2855E989 C923EEDF0EC7934B86AF
    RSA Public KEY E : 10001 (=65537)
    Fusebits : Same as before
  11. The Following 7 Users Say Thank You to kolimer For This Useful Post:
    alin 151 (22nd March, 2017), cocutanu (9th April, 2017), Col19 (13th November, 2019), humphrey (27th November, 2018), lupu_sandu (4th February, 2017), sabian (25th March, 2017), tintin2005 (2nd February, 2017)
  12. #279
    Feb 2017
    HW1 also known as 0x44
    HW2 also known as 0x46
  13. The Following 4 Users Say Thank You to kolimer For This Useful Post:
    cocutanu (9th April, 2017), Col19 (13th November, 2019), spacebiker (30th May, 2017), tintin2005 (2nd February, 2017)
  14. #280
    speedy100's Avatar
    Athens
    Quote Originally Posted by speedy100 View Post
    Anything for me guys???
  15. #281
    Feb 2013
    Share some pics first.
  16. The Following User Says Thank You to alexm1 For This Useful Post:
    speedy100 (2nd February, 2017)
  17. #282
    speedy100's Avatar
    Athens
    Quote Originally Posted by alexm1 View Post
    Here are some pics of it.
    B.R
  18. #283
    Feb 2013
    http://www.digital-kaos.co.uk/forums....php?p=2857128
    Start reading my old post #4579 from the link above.
    You need to have and to be able to use a soldering station, of course you need Avr programmer and find a pdf file called Tutorial (replace of LPT with AVR prog.)
  19. The Following User Says Thank You to alexm1 For This Useful Post:
    speedy100 (3rd February, 2017)
  20. #284
    speedy100's Avatar
    Athens
    Thank You!
    I will do and will come back with my results.
    Best Regards
  21. #285
    I have tried this 16.8 version with HW1 interface, but what fusebits should I use, witj cddcf9ff there is cnnection error almost all time. What VID pid should be?
