Page 20 of 30 FirstFirst ... 101516171819202122232425 ... LastLast
Results 286 to 300 of 444
  1. #286
    Feb 2013
    First of all, thanks for sharring your stuff!
    Now, I have 2 cables with Hd2 and I tried your dumps: interface test was ok, as you posted earlier, but did you test it on the car?
    It is necessary a new ept file for RL? I use old ept that works with 14.10.0 .
    I tried with a Fabia 2007 and I received several comunication errors: autoscan, each module, mass. blocks etc. it works to some point and than it crash.
    So, I use xtremeburner fusebits
    CD DC F9 CC, installed 16.8.0, copied cracked.exe in installation folder, delete main shortcut from the desktop and launch programm using cracked.exe .
    I did something wrong?
  2. #287
    Oct 2008
    On Earth
    CHINA tools used FTDI with VID/PID 0403/FA30 too
    You can change the FA24 ept in FA30 by yourself
    If you wanna waist your time
    You did All correct till now
    Good luck
  3. #288
    I tried HW1 RL tool with vid pid FA20 and have same situation, with FA24 test doesn't want to work, maybe I should try BL tool with FA20?
  4. #289
    Feb 2013
    I think cracked.exe file is not that "perfect" to make things work as should. Probablly @kolimer needs more time the make some changes for that dump to work with 16.8.0 . , if it is his work, otherwise he shares what he got without test it and this is it...
  5. #290
    Oct 2008
    On Earth
    @ Mr 16D
    I tested All
    Ft232 Rl with FA24 and FA30
    FT232BL with FA20
    I tried both firmware version shared for each
    I Also tried woth original firmware 256b wirds and 512b words
    Non of item ia working
    I think you are waisting your time.
    I think the problem.is the loader utself and/or the firmwares which are not the original one used in Genuine tools
    Good luck
  6. The Following User Says Thank You to mattydr67 For This Useful Post:
    paro44 (9th February, 2017)
  7. #291
    Jan 2017
    Hey guys,
    thanx for sharing all the information with us, but could someone please have a look over my post over there --> http://www.digital-kaos.co.uk/forums...=1#post2927162 ?
    Thank you very much, I just don't want to kill my cable, if I do something wrong.
    Good fight, good night!
    ni88l3r
  8. #292
    Oct 2008
    On Earth
    Mate in your case MFT version you are using a loader because the serial its blacklisted and when younare using the original exe file your tool will show you unregistred.
    If a tool it has the rght serial not blacklisted then its doesn't matter if it is with BL/BM ( old style ) or RL/RQ ( nrw style)
    To flash the tool
    - flash with MProg the FTDI using ept for BL/BM ( vid/pid 0403/FA20 )
    - Connect your AVR Programmer to Atmega ISP pins ( MiSO/MOSI/SCK/RESET) and GND
    - Power the circuit ( VCDS ) with 12V ( from car if you wish ) on OBD pins (16 for +12v and 4-5 for GND )
    Use the eeprom that you have and fuse bits CD/DC/F9/CC or FF
    Tthis is it
    Well I forgot if you have STC in circuit as you said you need to insolder the STC and the other two components
    Good luck
  9. The Following 3 Users Say Thank You to mattydr67 For This Useful Post:
    ireun (9th February, 2017), ni88l3r (8th February, 2017), paro44 (9th February, 2017)
  10. #293
    Hungary
    The 16.8 cracked software still crashes (comm error). The 12.12 and the 11.11.5 sw say license not found. I used the 0403 FA20 config and Flash1.96_HW1.bin and the eeprom (HEX 2011/03/01 12h19:58). My cable consists ATMEGA162, GAL, 93c46, FT232BL na no ST. The cable worked fine with 1.84fw. I used ponyprog for programming ATMEGA, using the attached fuse settings. ATMEGA is connected to the GAL.
    Thanks,
  11. #294
    Feb 2017
    I will try to investigate where should be the problem. But it will take some time.
  12. The Following 8 Users Say Thank You to kolimer For This Useful Post:
    1 6 D (8th February, 2017), alexm1 (8th February, 2017), Col19 (13th November, 2019), ireun (9th February, 2017), oleg68 (9th February, 2017), paro44 (9th February, 2017), sabian (25th March, 2017), VWfan (13th January, 2019)
  13. #295
    Hungary
    The license is okay with the 1.96Fw. I think the cracked .exe is not working properly.
  14. #296
    Quote Originally Posted by mattydr67 View Post
    Good luck
    As i know, 15.7.0 and 16.8.0 CHN with STC use FA24.
    15.7.0 has in my hand, saw eeprom, extracted vcds.exe for use without "stc protection'.
    Worked ok. But with proper eeprom, not tried to "whitening" an old blacked serial.
    Probably is the same in 16.8.0 EN CHN STC. Haven't yet one.
    But..like more others CHN versions...
  15. #297
    DK Veteran kevino's Avatar
    Slovakia
    hi guys, here is foto of my clon cable. It is 10.6.4.czech version. i need to repair so what files is good for my cable ? thank you for advice.
    IMG_20170219_105129_změnit velikost.jpgIMG_20170219_105147_změnit velikost.jpg
    VCDS 17.1.3, Xprog M 5.0
  16. #298
    Menber's Avatar
    Feb 2017
    Good evening!
    Just to say that it was a long but really exciting reading ...
    Since my cable is still functional I will not venture to modify it for now but knows one never afterwards ???
    Anyway I thank all the members who helped make this post very pleasant to read ...
  17. #299
    Nov 2015
    Hello, I have the original VCDs, it burned down FT232RQ. I it desolder, but the test does not pass. I applied for help in Ross-Tech, but they did not offer me a solution. Send USA repair HW is not variant. The program shows:
    What am I doing wrong? Help my Pleas.
    Thank You.
    P.S.:Sorry my bad English.
  18. #300
    Oct 2008
    On Earth
    FTDI is a part of protection in VCDS
    You damage it you need one with same Id.
    But the Id is uniq snd tge rste to buy one with same ID its higher then to win in lottery
    Tgis mean th the dump in the MCU Atmega is marriaged with the ID of the defective FTDI.
    You did two bad steps
    1. You open the case
    2. You change tge FTDI by yourself
    Ross-tech warranty is out in this case but they are the only one who can help you in this moment. No one can do it.
    At leaxt if you want that tool to be a genuine one from now on.
    Good luck
  19. The Following User Says Thank You to mattydr67 For This Useful Post:
    darka7 (5th March, 2017)
