Page 23 of 30 FirstFirst ... 131819202122232425262728 ... LastLast
Results 331 to 345 of 444
  1. #331
    hello to all
    i have an vcds 15.7 eng its possible to change in frenche
    best regards
  2. #332
    Jul 2017
    Quote Originally Posted by wallix89 View Post
    Hi everyone. I have vag 12.12.0 chinese clone. worked fine for a while, and in one day when i tried to do a auto-scan, at some point showed me the message 'this function requires a licensed interface'. i checked 'about' and it shows unregistered. i used the software that came with the cable, which prompts to close internet con, and changes the date automatically. it's like a demo. i still can do some things whith it. any chance to make it fully working again? thanks in advance. sorry for my poor english .
    My exact situation, probably same hardware.
    16D: as my latest post on VAG-COM/VCDS EVERYTHING it is equipped with FT232RL, ATMEGA162, ATF16V8B
    Just to restore original 12.12.0 to a working condition what do we really need ??
    Shoul ATMEGA be rewritten by 4 soldered wires or via USB also ??
  3. #333
    Jul 2017
  4. #334
    user2468's Avatar
    Planet Earth
    If your VAG-Com Interface is clone then only by wires with isp programmer you can burn new flash in Atmega162.
    If my post was helpful than Please don't forget to press the Magic word
  5. #335
    Hi User2468,
    somehow off topic but I can not write you a PM because your Inbox storage is full!
    I just found a post from you that you have fixed your 912 Tacho universal dongle and make it work.
    Could you please tell me how to do so?
    Mine is not working and I read a lot of posts, but my R1 and R2 resistors seems to be correct around.
    Could you please tell me how you fixed yours and what is written on the parts of your one for R1, R2, C4 & C4/1?
    Thank you!
    DC
    As mentioned, sorry for the off topic.
  6. #336
    Jul 2017
    Hi everybody,
    I am using vcds 11.11.0 with loader (i have RL). I want to upgrade dump to 12.12. Is there any loader for "VCDS-Release-12.12.0-Installer English 512bits" ?
  7. #337
    Jan 2016
    You can upgrade to 17.1. Instructions are in other VagCom thread
  8. #338
    May 2011
    Hi all.
    Can anybody place here file .ept from original vcds with ft232rq chip?
    My VCDS is dead, I change the chip and need to program it with mprog.
    I have original VCDS
    Regards.
  9. #339
    xoom's Avatar
    Ylakiai
    You cannot change Unique ID of this chip as it's hardcoded. And afaik that ID is attached to you license.. even Ross-tech wont help you there
  10. #340
    Aug 2016
    Muchas gracias por todo lo aportado
    Saludos Dardo
  11. #341
    Nov 2017
    Sorry for my lack of knowledge, but how do I flash a .bin dump to the eeprom? Thanks.
  12. #342
    Nov 2017
    Hi Guys,
    I have a question about my VCDS cable and I could not find any other threads where I could ask this.
    My cable stopped working a while ago. I cannot change long coding, only adaptation. When changing Long Coding it says coding accepted, but then the actual coding is never updated.
    I added pictures of my cable. I cannot see atmega or ftdi chip on it.
    Can I get it working again somehow?
    Thanks!
    Regards,
    /Kopel
  13. #343
    Feb 2013
    Your cable it has FTDI - RL (second picture very close to those 4 wires(usb) soldered to pcb.
    It does not have Atmega, it is with NEC=CHINA= No chance to update (reflash) as I now, maybe this fact will change in the future..
    About long coding- it must be vers. 12.12.0 - it is known that fact- coding saved, but at next visit coding not changed.
    L.E. - it is very low quality- no GAL/ATF, no LM7805. ...do not waste your time, buy one with Atmega.
  14. #344
    Nov 2017
    Thanks for the info!
    I will try to get one with atmega then.
    I have 14.04 VCDS english version. Got this with a CD coming with the cable. But maybe this version has the same fault.
    Thanks!
  15. The Following User Says Thank You to kopel For This Useful Post:
    peewack (23rd July, 2018)
  16. #345
    Jun 2017
    Hi Boys ! This is all what you need to work with VCDS_17.8.0 and Clone unit
    Frimware and Software + Instructions
    Pass pm and only for real members DK
  17. The Following 11 Users Say Thank You to jokeriphone For This Useful Post:
    alexm1 (8th December, 2017), eliotroyano (10th December, 2017), FoxMulder (8th December, 2017), marki (17th June, 2019), mototik (1st May, 2018), mps125 (24th December, 2017), nenadrossi (22nd March, 2018), peewack (23rd July, 2018), PhilipArt (29th October, 2018), ritadj (16th January, 2018)
