Page 29 of 30 FirstFirst ... 1924252627282930 LastLast
Results 421 to 435 of 441
  1. #421
    Jul 2020
    Why i can't download from the forum?
  2. #422
    Aug 2020
    Hello everyone I have bought a cable HEX-V2 Dual K & CAN; the package had a cd with loader when i first installed it and connected it to the car ; the vcd keeps asking me to pass the test and a message box appears with the following: Port status : OK
    USB Library Version: 03.02.07
    USB driver Version : 02.10.00
    Interface Found!
    Type: Ross-Tech HEX-USB
    Status: not Plugged into Car!
    What should I do?Would any one help please.
    Thanks and regards
  3. #423
    Jan 2016
    Quote Originally Posted by temusr View Post
    Interface Found!
    Thanks and regards
    Test shows that it is not V2 but HEX-USB
    Probably you have low quality device or use bad loader or version itself. If it is good you can flash it and get good dump to use with latest version. Post picture of PCB but you have all information on other thread HERE
  4. The Following User Says Thank You to jakuza For This Useful Post:
    temusr (31st August, 2020)
  5. #424
    Aug 2020
    Quote Originally Posted by jakuza View Post
    First I'd like to thank you for the reply and appreciate your help much; would you please give me a list of tools required to reflash and where to get the dump file to program the atmeg; what happened to the cable was I thought a cloned cable an original one so, I went to ross tech and downloaded the latest software and ran it without any loader I was naive ; it seems to me that an original software got it disabled. I plaued with couple of tools that programmed the FTDI USB interface but I couldn't get to the atmeg controller even with a boot loader to program.
  6. #425
    Aug 2020
    I played with couple of tools that programmed the FTDI USB interface but I couldn't get to the atmeg controller even with a boot loader to program.
    I ordered USBASP programmer from local dealer. But I need a road map; I know about lots of things now the atmeg is used to communicate to car and ftdi is usb controller i know about pin outs of the obd; I know about ftdi FTDI232RL which is my case MY GAL controller is PALCE
    I have been searching, studying your forum and ink you gave earlier, I'm still feeling confused that makes me ask your help once more for a roadmap/steps and dump/tools if it does not bother You.
  7. #426
    Top Poster luisfm's Avatar
    Feb 2013
    hi i got this vagcom 11.11 locked for update and i want to get it back.
    What last update can I do?
    What eprom download and upload software should I use?
    please help thanks
  8. #427
    May 2013
  9. #428
    leonida's Avatar
    Oct 2016
    Thessaloniki, Greece
    Hi!
    I have one old VCDS interface, Wenas project,FT232BL,Atmega162,GAL...
    Is it possible to reprogram this hardware to work with some newer software that supports UDS ?
    If anyone shares the appropriate dumps I will be grateful
  10. #429
    Mar 2018
    UK
    can someone share 12.10 or 12.12
    I found some likns to mega but not working
  11. #430
    Mar 2022
    Hi, I have the same problem. Have you managed to fix it?
  12. #431
    Jul 2022
    Hello everyone,
    I have an Atmega 162 and FT232bl chip (chinese wire) in VAG12.12 firmware.
    The wire been updated because i have let the internet connection run i think. I think that because i have a windows with a message "sorry , this function requiert a licencied interface when try to acces" to "04 basic setting" in the controller 53 parking brake.
    The wire working fine before...
    Please can someone help me for update my wire to a workable version ?
    https://ibb.co/vZW7mhx
    https://ibb.co/58qBBb1
  13. #432
    Aug 2018
    Romania
    Do not forget to press Thanks and Reputation buttons!
  14. The Following User Says Thank You to sebage For This Useful Post:
    tIZIAN777 (10th July, 2022)
  15. #433
    Jul 2022
    Thank you for your help, my wire is revived and upgraded at the last version !
  16. #434
    Apr 2022
    Hi!
    Could you help me to repair this cable?
    thanks for your answer!
  17. #435
    Dec 2022
    Good evening friends, I am trying to recover a cable that I used with version 12.12.
    I'm trying to follow what "gopelhu" indicated in this link: https://www.digital-kaos.co.uk/forum...=1#post2725896
    The problem is that the link is out of service and I can't get the installer file for vcds 12.12 512bits, does anyone have it available to share please? or is there another solution other than using that installer?
    My hardware has the following components:
    ftdi=FT232RL
    atmega162
    MCP2515
    TJA1050
    I thank you in advance and I apologize since surely there are more solutions and I may have missed some among so much information, greetings!
