Page 3 of 30 FirstFirst 1234567813 ... LastLast
Results 31 to 45 of 444
  1. #31
    DK Veteran KenshinPT's Avatar
    PT
    Quote Originally Posted by Africa View Post
    my interface stopped working, the computer does not recognize it interface.
    Read EEPROM successful Device 0
    0000 : 55 46 55 46 55 46 55 46 55 46 55 46 55 46 55 46 FU FU FU FU FU FU FU FU
    0010 : 55 46 55 46 55 46 55 46 55 46 55 46 55 46 55 46 FU FU FU FU FU FU FU FU
    0020 : 55 46 55 46 55 46 55 46 55 46 55 46 55 46 55 46 FU FU FU FU FU FU FU FU
    0030 : 55 46 55 46 55 46 55 46 55 46 55 46 55 46 55 46 FU FU FU FU FU FU FU FU
    0040 : 55 46 55 46 55 46 55 46 55 46 55 46 55 46 55 46 FU FU FU FU FU FU FU FU
    0050 : 55 46 55 46 55 46 55 46 55 46 55 46 55 46 55 46 FU FU FU FU FU FU FU FU
    0060 : 55 46 55 46 55 46 55 46 55 46 55 46 55 46 55 46 FU FU FU FU FU FU FU FU
    0070 : 55 46 55 46 55 46 55 46 55 46 55 46 55 46 55 46 FU FU FU FU FU FU FU FU
    What could be the reason? ...
    E2prom enough to program?
    I need to program the 93C56.
    Any help?
    thanks.
    As far as I know... "FU" means that you " F*cked Up " the EEPROM
    You need to reflash it again. Use MPROG. You can find the dumps here in the forum.
    Also, ATMEGA might be compromised. If so, you should reflash it again. Dumps are also available.
    Good luck.
    Did it help? Push Thanks below
  2. The Following User Says Thank You to KenshinPT For This Useful Post:
    gopelhu (23rd February, 2016)
  3. #32
    Top Poster Africa's Avatar
    I've been reading a 93c46 eeprom, but my interface contains 93C56.
    Is there anyone who can help me?
    Original BDM EVC with adapters, SPI EVC, Galep5 programmer, emp11 programmer, upa1.3, kwp2000plus, MPPS, Ktag, Kess, Galletto ofiicial, and many more...
  4. #33
    DK Veteran Artilect's Avatar
    EU
    Try with this VAG-COM Revival to properly recognize the device. Then load new dump with MProg.
    BR
    __________________
    If You Like My Post
    Please use the button on the LEFT side and the button on the RIGHT side.
    Tuning, EGR, DPF, AdBlue, DTC, TVA, Speed Limit, Immo...
  5. The Following 18 Users Say Thank You to Artilect For This Useful Post:
    amor89 (9th March, 2018), bolke322 (14th January, 2023), cobar (7th April, 2022), Col19 (13th November, 2019), ecufix (9th July, 2014), eriklll (20th January, 2020), exstrigen (1st October, 2023), hendriono (31st October, 2017), jakesman (14th December, 2014), jo?o antonio (4th August, 2016), milerk (1st April, 2017), n599fbm (8th May, 2016), nelumuresan (26th May, 2017), semga (8th October, 2015), temusr (11th August, 2020), tolisnancy (2nd October, 2018), tyrystor (10th July, 2021)
  6. #34
    Quote Originally Posted by Artilect View Post
    BR
    thanks. i test tomorrow.
  7. The Following User Says Thank You to Africa For This Useful Post:
    Andrea80 (19th February, 2016)
  8. #35
    Oct 2012
    thanks from me
  9. #36
    Nov 2008
    places
    thanks. used files in first post and all fixed up.
    genuine tools owned: too many
    genuine software owned: have lost count
  10. #37
    Oct 2012
    thanks im test and work perfectly vag com 908 en
  11. #38
    Actual free English dual is for VCDS 11.11.0 is in this post:
    http://www.digital-kaos.co.uk/forums...ml#post1647476
    Here is loader if it's RL clone:
    http://www.digital-kaos.co.uk/forums...ml#post1644621
  12. #39
    hi
    i have vag com 908 not work with car
    please hilp me thanks
  13. The Following User Says Thank You to bahlawi For This Useful Post:
    yass (27th June, 2013)
  14. #40
    Quote Originally Posted by bahlawi View Post
    hi
    Reprogram Atmega but first erase it and then flash and eeprom and fuse/lock bits
  15. The Following User Says Thank You to gelomeloman For This Useful Post:
  16. #41
    Feb 2013
    Hi im looking for a ept dump for vag cable 113
  17. #42
    May 2012
    i have an perfect working cable from sklad how i can dump it to take it here online its the newewst 11.11.5 DRV GErman version
    Leo
  18. #43
    You needt to read flash and eeprom file from Atmega162 from your cable. You can use Ponyprog or UPA (if you have it).
    Ponyprog is easy to use - feev connections nad free LPT port on PC and go
  19. #44
    Hi all
    Someone corect working dump for ATMEGA162 the Czech version?
    10.6.4 and newer?
    I do not want it free ...PM
    thx
  20. #45
    snatchme's Avatar
    Dec 2010
    Dutchie
    Default Problem with original VCDS HEX-CAN
    I have here an original VCDS interface but it stopped working.
    Was working on a SEAT re-coded original Touchscreen radio. everithing went O.K. wanted to go to Instrument cluster for service reset.
    and get the Message "not plugged into car".
    did interface test, interface found and connected but not plugged into car message.
    Green light is "On" did check with 2 laptops and 2 cars always same message.
    have last SW on laptop and last Firmware on interface. do you know how to get it running again?
    I have FTDI232RL inside with USB VID 0403 and PID FA24.
    I have also tried to contact ross-tech but they do not reply to my e-mails.
    Thanks for helping.
    Greetz
    Snatchme
  21. The Following User Says Thank You to snatchme For This Useful Post:
    macalister (1st August, 2016)
