VAG-COM/VCDS LATEST DUMPS - Page 4
Page 4 of 30 FirstFirst 12345678914 ... LastLast
Results 46 to 60 of 441
  1. #46
    Nov 2011
    Thanks!!! i really needed it
  2. #47
    Nov 2011
    Default Thanks
    i been looking for the vag revival for a long time thanks
  3. #48
    alldecode's Avatar
    EU, Croatia
    I have interface for VCDS like on picture
    ver 11.11
    but not work
    led flashing red, when conect to car its green, but sw not see cable
    VID 0403 PID FA24
    on interface missing 7805, atmega is on usb power, and no GAL chip
    wich version to update on this cable to work OK?
  4. #49
    Oct 2008
    On Earth
    Mate
    This tool comes with a dedicated VCDS softwear.
    If I know well it is v11.11.3
    Did you use this one?
    And please share pics with the message that you show after you do TEST
    and from ABOUT
    Maybe you do something wrong and you do not need to reflash the Atmega
    BTW this is the worst tool made VCDS made in China I ever seen
    Good luck
  5. The Following 2 Users Say Thank You to mattydr67 For This Useful Post:
    mladen76 (30th March, 2013)
  6. #50
    Top Poster + mladen76's Avatar
    By the see
    Everything to cut expence and to improve profit...
    I guess price is the same like one that have all chips
    My advice-send them back that shit they send you if you have a chance to get money back...
  7. #51
    alldecode's Avatar
    EU, Croatia
    yes, I sent back 4 peaces, and pay post, i have refund money, but last week i recive back packet with this cable (becouse wrong adress) then I try to repair.
    this is error message from sw 11-11-3
  8. #52
    alldecode's Avatar
    EU, Croatia
    USB\VID_0403&PID_FA20.DeviceDesc="Ross-Tech HEX or KEY USB Interface"
    USB\VID_0403&PID_FA23.DeviceDesc="Ross-Tech Micro-CAN Interface"
    USB\VID_0403&PID_FA24.DeviceDesc="Ross-Tech Direct USB Interface"
    USB\VID_0403&PID_DF20.DeviceDesc="Ross-Tech USB Converter"
    USB\VID_0403&PID_FA30.DeviceDesc="Ross-Tech Direct Interface"
    this is part from rt-usb.ini file, I try put all of then, but same problem.
    mybe atmega ic clear, ... In first start program, and conect vcds to usb, vcds try to find driver, but driver not find, PID is wrong, I dont know which PID is writen to cable
    someone who have flash and ept file, then I try to reprogram. Mybe then work
  9. #53
    Oct 2008
    On Earth
    For your interface the VID/PID must be this:
    Use MProg and change the FA24 into FA30
    Then must be recognized.
    Good luck
  10. #54
    mexanico1971's Avatar
    portugal
    why I can not program the fuses and the bit"s ?!
    I bean able to erase the AT162 but not write it !
    UPA ori say"s that is successfully programmed but is not !
    what possible could be ?!
    BR
    My work is my life ART TECH GARAGE
  11. #55
    alldecode's Avatar
    EU, Croatia
    Ok, "mattydr67", i put FA30
    but, when i first run, i run over sw 11.11 (becouse i dont now that is 11.11.3), in 11.11 driver is not FA30, my mistake
    look
    now i change PID
    end this is error message:
    what now?
  12. #56
    alldecode's Avatar
    EU, Croatia
    in one cable give mi this error:
    sw is 1.84 and upgrade to 1.91, then upgrade is over, cabal works
    now i have 3 peaces, and try to directly flash with 1.84 (11.11) then upgrade, maybe be sucess
  13. #57
    Oct 2008
    On Earth
    Mate use the softwear that comes with interface.
    That kind of tool that you have it is usually sold with VCDS 11.11.3 softwear.
    As I allready told you the VCDS 11.11. it is generic. There's 11.11.0 version, 11.11.1, .....11.11.5
    And your tool dump works just one version of VCDS that comes with the interface not with other.
    That's why it said "Interface Not Found"
    Good luck
  14. The Following User Says Thank You to mattydr67 For This Useful Post:
    alldecode (30th March, 2013)
  15. #58
    alldecode's Avatar
    EU, Croatia
    "mexanico1971"
    I programing atmega with pony, and is OK
    try to ponyprog, are you have schematic for interface?
  16. The Following User Says Thank You to alldecode For This Useful Post:
    mexanico1971 (31st March, 2013)
  17. #59
    alldecode's Avatar
    EU, Croatia
    OK, matty... but if i have newer sw, like 11.11.4 and higer, that sw upgrade interface without directly flash atmega?
  18. #60
    Oct 2008
    On Earth
    No mate
    The softwear upgrade just the firmwear in the Atmega.
    And this just if you have a not blacklisted serial in the Atmega eeprom
    I suppose you have a blacklisted serial so you cannot upgrade it.
    If you allready tried this then you need to reflash your tool with a dump and use the version of VCDS for that dump.
    Good luck
