Page 5 of 30 FirstFirst 1234567891015 ... LastLast
Results 61 to 75 of 444
  1. #61
    alldecode's Avatar
    EU, Croatia
    did you have maybe 11.11.3 dump to try reflesh atmega (i have 11.11)
  2. #62
    Oct 2008
    On Earth
    Mate
    I have of course but dumps aren't for share
    Sorry
    Good luck
    P.S. - the last free dump you can find it is for VCDS 11.11.0
    If you have a RL tool you need a loader too
  3. #63
    alldecode's Avatar
    EU, Croatia
    I have dump 11.11, and tomorrow try tu upload to atmega, then change fireware with vcds. Maybe sucess
    what you mean: If you have a RL tool you need a loader too
  4. #64
    Oct 2008
    On Earth
    VCDS are with FTDI BL/BM or with FTDI RL
    Fot the tool with FTDI BL/BM you don't need loader, for the tool with FTDI RL you need loader
    Good luck
  5. #65
    alldecode's Avatar
    EU, Croatia
    OK, loader
    i try to conect with car, and OK, but if i try to coding, error mesage... not registred ... on CD not find loader, do you have?
    I buy many VCDS from china, and never use loader, why loader must use?
  6. #66
    Oct 2008
    On Earth
    The tools with RL from China use their softwear for that tool.
    Loader including or it is made in other way.
    The loader it used when you use let's say VCDS 11.11.0 with original softwear but for the tool with RL ( becasue the dump in VCDS 11.11.0 it is for tools with FTDI BL/BM and no FTDI ID - FTDI RL has an ID so the loader will pass it )
    Good luck
    P.S> - your tool need to be reflashed
  7. #67
    Tested VCDS 11.11.0 dump
    hex files are for pony prog, bin files for upa.
    Here you can find dump (Atmega flash+eeprom)
    Use VCDS 11.11.0 loader if you have a RL interface. Remove rar extension from filepart of VCDS software.
    When programming, keep in mind correct order:
    1. CHIP ERASE
    2. FLASH
    3. EPROM
    4. FUSE BITS
    5. LOCK BITS
    VCDS v11.11 ATMEGA162 Fuses & Lock bits
    # LOCK: 0b11111100
    # bit 7 = -
    # bit 6 = -
    # bit 5 = BLB12 (1)
    # bit 4 = BLB11 (1)
    # bit 3 = BLB02 (1)
    # bit 2 = BLB01 (1)
    # bit 1 = LB2 (0)
    # bit 0 = LB1 (0)
    # EFUSE: 0b11111001
    # bit 7 = -
    # bit 6 = -
    # bit 5 = -
    # bit 4 = M161C (1)
    # bit 3 = BODLEVEL2 (1)
    # bit 2 = BODLEVEL1 (0)
    # bit 1 = BODLEVEL0 (0)
    # bit 0 = -
    # LFUSE: 0b11111101
    # bit 7 = CKDIV8 (1)
    # bit 6 = CKOUT (1)
    # bit 5..4 = SUT1:0 (11)
    # bit 3..0 = CKSEL3:0 (1101)
    # HFUSE: 0b11011100
    # bit 7 = OCDEN (1)
    # bit 6 = JTAGEN (1)
    # bit 5 = SPIEN (0)
    # bit 4 = WDTON (1)
    # bit 3 = EESAVE (1)
    # bit 2 = BOOTSZ1 (1)
    # bit 1 = BOOTSZ0 (0)
    # bit 0 = BOOTRST (0)
  8. The Following 22 Users Say Thank You to betonel For This Useful Post:
    BigJ (16th October, 2014), Col19 (13th November, 2019), ecufix (9th July, 2014), jl01152 (30th October, 2020), Jonnybgud (4th March, 2018), M.Jojo (4th February, 2016), madbg (2nd May, 2014), matrox018 (23rd April, 2024), micassu (5th May, 2017), Mrjitter (11th January, 2017), n599fbm (8th May, 2016), Panchez (11th January, 2017), pismar (10th May, 2014), sasa5 (25th January, 2015), schin (28th June, 2019), TeiS (28th July, 2014), tripcreator (22nd July, 2024), tyrystor (10th July, 2021), vcelar (26th December, 2014), VWfan (13th January, 2019), youssef70 (11th November, 2014), zoro1 (27th April, 2016)
  9. #68
    Jun 2013
    Have someone some neewest flash and ee for 11.11.3 pl? i have 10.5.5 but looking for somethink new.
  10. #69
    Quote Originally Posted by betonel View Post
    1. CHIP ERASE
    2. FLASH
    3. EPROM
    4. FUSE BITS
    5. LOCK BITS
    # LOCK: 0b11111100
    # bit 7 = -
    # bit 6 = -
    # bit 5 = BLB12 (1)
    # bit 4 = BLB11 (1)
    # bit 3 = BLB02 (1)
    # bit 2 = BLB01 (1)
    # bit 1 = LB2 (0)
    # bit 0 = LB1 (0)
    # EFUSE: 0b11111001
    # bit 7 = -
    # bit 6 = -
    # bit 5 = -
    # bit 4 = M161C (1)
    # bit 0 = -
    # LFUSE: 0b11111101
    # bit 6 = CKOUT (1)
    # HFUSE: 0b11011100
    # bit 7 = OCDEN (1)
    # bit 5 = SPIEN (0)
    # bit 4 = WDTON (1)
    Betonel can you check fuse & lock bits because I have seen others in the past. Please check out attachment.Fuse Bits & Locks.jpg
  11. The Following User Says Thank You to eliotroyano For This Useful Post:
  12. #70
    Quote Originally Posted by eliotroyano View Post
    Anyone can confirm the fuse & lock bits posted for VCDS 11.11.0?
  13. #71
    Jan 2015
    1. CHIP ERASE
    2. FLASH
    3. EPROM
    4. FUSE BITS
    5. LOCK BITS
    # LOCK: 0b11111100
    # bit 7 = -
    # bit 6 = -
    # bit 5 = BLB12 (1)
    # bit 4 = BLB11 (1)
    # bit 3 = BLB02 (1)
    # bit 2 = BLB01 (1)
    # bit 1 = LB2 (0)
    # bit 0 = LB1 (0)
    # EFUSE: 0b11111001
    # bit 7 = -
    # bit 6 = -
    # bit 5 = -
    # bit 4 = M161C (1)
    # bit 0 = -
    # LFUSE: 0b11111101
    # bit 6 = CKOUT (1)
    # HFUSE: 0b11011100
    # bit 7 = OCDEN (1)
    # bit 5 = SPIEN (0)
    # bit 4 = WDTON (1)
    zip archives damaged
  14. #72
    dimet's Avatar
    MKD
    1. CHIP ERASE
    2. FLASH
    3. EPROM
    4. FUSE BITS
    5. LOCK BITS
    # LOCK: 0b11111100
    # bit 7 = -
    # bit 6 = -
    # bit 5 = BLB12 (1)
    # bit 4 = BLB11 (1)
    # bit 3 = BLB02 (1)
    # bit 2 = BLB01 (1)
    # bit 1 = LB2 (0)
    # bit 0 = LB1 (0)
    # EFUSE: 0b11111001
    # bit 7 = -
    # bit 6 = -
    # bit 5 = -
    # bit 4 = M161C (1)
    # bit 0 = -
    # LFUSE: 0b11111101
    # bit 6 = CKOUT (1)
    # HFUSE: 0b11011100
    # bit 7 = OCDEN (1)
    # bit 5 = SPIEN (0)
    # bit 4 = WDTON (1)
    Please update damaged archives
  15. #73
    simaservis1108's Avatar
    Aug 2013
    Serbia,Belgrade
    Since my VCDS was bricked,I used above dump 11.11.0.
    Interface is alive now,but when I connect to CAN,I can work 10 seconds,then I am disconnected,and have to unplug/replug USB and restart VCDS.
    Is there any solution to this?
  16. #74
    BiH
    Hello to all i have a vcds interface 12.10 clone with beta sw. is there any version of vcds original software that can be used on this interface..Thank you
  17. #75
    Jan 2012
    Hello kidloco,
    With VCDS chinese clone interface, you must only use the install executable that come with interface on CD-ROM.
    There is a risk to block the interface if you try an another install executable.
    My automotive tool :
    ? VCDS clone/copy interface but non-chinese
    compatible with last versions (v15.1.0, v14.10.0, v12.12.3, ...)
    and with free online updates for future versions.
