Please i need info how to make VCDS 12.10 with FTDI RL to any original VCDS Version example 11.11.0. thank you
Look at the big "vcds everything" thread, you can find there the aminebot tutorial for repair.
You can't make an original, since the public serials are blacklisted in software. Software update an internet connection will disable your interface.
Hello kidloco,
With VCDS chinese clone interface, you must only use the install executable that come with interface on CD-ROM.
There is a risk to block the interface if you try an another install executable.
My automotive tool :
? VCDS clone/copy interface but non-chinese
compatible with last versions (v15.1.0, v14.10.0, v12.12.3, ...)
and with free online updates for future versions.
Thx, i was lokking there but could not find aminebot tutorial ,, plase can you give me a link or ...
Hello. I need advice for relfashing atmega vie LPT. I can write eeprom but can't write flash.Witch format do I have use .bin or .hex? Thanks.
hello,
is possible to repair china cable vag912 ?
Hallo,I need tutorials to make VCDS interface from Chinese clone ELM 327 USB v1.5a.Could some people help me please with it...was trying to download that VCDS all rar.file, but got a mistake.Thx.
Last edited by olegdon; 15th February, 2016 at 12:54 PM. Reason: To add information
Hi all,
Here is my solution, ENJOY !!!
config with ponyprog, and installer very big size and i caanot upload it.
if anybody need it pl write me pm.
Regards,
Col19 (13th November, 2019), erodriguez18 (20th March, 2018), nelumuresan (31st October, 2016)
Hi there,
New here, due to a bricked Chinese vag-com interface 11.11 :/
Made a stupid mistake. Looking to see if I can just use vag-com revival to reprogram or if I need to do much more. Sorry, I know these are noob questions.
Hello, I have a HEX + CAN DUAL-K CAN USB interface.
Unfortunately, I have used a newer VCDS software and it asked me for a FW update from 1.92 to 1.94. Now unfortunately gone Something wrong and he accepts the connection but no longer recognize the interface.
The FTDI FT Prog recognize it perfectly. Can anyone help to liven up the part to me again?
Device Info from FTDI:
Chip Type: FT232R
Vendor ID: 0x0403
Product ID: 0x6001
Product Desc: Ross-Tech
Location ID: 0x11
EEPROM Type: 93C56 EEPROM
Hope it can someone help.
Am I in the right place in the category? Any ideas what is wrong with the cable now?
I would be really grateful for your solutions.
Is there someone who can help?
Gesendet von meinem C6603 mit Tapatalk
push
if original software used then your atmega has been wiped
you need to reprogram the interface
look inside interface and see what mcu is there if atmega your ok and can fix but if nec then best buy another
Gizimo (3rd January, 2016)
Big Thanks Tango, for your Help.
Chip is an
ATMEGA162
16AU
1308H
