Page 7 of 30 FirstFirst ... 2345678910111217 ... LastLast
Results 91 to 105 of 444
  1. #91
    Newbie Gizimo's Avatar
    Dec 2015
    My brother gave me the stuff.
    But apparently wrong software, because he could not find the CD.
    He gave me "VCDS-DRV-11115-Installer.exe", but the thing just would not be installed. On my XP laptop.
    I tried it then with "VCDS15070DE-Setup.exe".
    He told me it was all original. That's why I made the ~~~~ FW update from 1.92 to 1.94.
    Then the interface disappeared in the recognition.
    I thank you so much for the help.
    I hope I have the brother not to buy a cable.
  2. #92
    Oct 2008
    On Earth
    Don't worry about firmware upgrade. This is not the reason that the tool is not working now.
    The reason is that you don't use the right software for it.
    On one side there is a s/n. You can contact sklad66 maybe will help you.
    Who knows. Anyway if you didn't touched the tool in anyway. I mean if you didn't reflashed the ftdi with ftprog and much more then this if you didn't touched the Atmega162 MCU tring to reflash it then could be a hope to make it works again.
    Good luck
  3. The Following User Says Thank You to mattydr67 For This Useful Post:
    Gizimo (5th January, 2016)
  4. #93
    Dec 2015
    I have not changed anything on the device. I've googled Slkad66. Sklad66.com is offline. Does anyone know a way to repair the unit?
    Gesendet von meinem C6603 mit Tapatalk
  5. #94
    Oct 2008
    On Earth
    Mate you don't follow me at all
    I told you that if you didn't touch it you didn't brick it.
    So you don't need to fix it you only need the vcds software for your tool.
    But versions after 14.10
    Good luck
  6. The Following User Says Thank You to mattydr67 For This Useful Post:
  7. #95
    Dec 2015
    Sorry, my English is not so good. I just make me worry, because before the FW update the original software has found the interface and recognize the cable. Now the cable is only detected by FTDI.
    Where can I find the right software?
  8. #96
    Oct 2008
    On Earth
    Quote Originally Posted by Gizimo View Post
    Good question. From one who have it and wants to share it.
    Good luck
  9. The Following User Says Thank You to mattydr67 For This Useful Post:
  10. #97
    Dec 2012
    Hmm these tools never shipped with cd but if you send me pic outer case in pm i might share 1 version to try but only if you send me them pic in private
  11. The Following User Says Thank You to gazvts For This Useful Post:
    Gizimo (6th January, 2016)
  12. #98
    Jan 2016
    thanks for help
  13. #99
    Jan 2016
    Hi all,
    I have a DUAL-K CAN USB VAG/ISO chinese interface.
    back label "VCDS1103"
    inside is:
    FT232BL
    ATMEGA162-16AU
    EEPROM: 93C46
    PALCE16V8H-10JC/4
    MCP2515
    MCP2551
    7805
    windows device manager say:
    FTDIBUS\VID_0403+PID_6001+5&2C5C6891&0&8\0000
    FTDIBUS\COMPORT&VID_0403&PID_6001
    Unfortunately, I have used a wrong VCDS software
    Need to reprogram the interface and
    suitable VCDS software
    Please if you can help me with hex and everything needed. (fusebit setting for PonyProg...)
    Thanks a lot!
  14. #100
    Oct 2011
    Hi all,
    I have a interface working with a french version of VCDS. I have let it to a friend and i try to use it with an official version. Now my interface doesn't work. I have the message not connected to the car. (I see that the led stay blank)
    Do you have an idea to try to repair it. (I have made a record of the atmega with my usbasp some time ago with extreme burner air, but it's seem to be not enough.
  15. #101
    Oct 2008
    On Earth
    Share few pics mate with your error and tell us if the serial is Unregistred.
    You have a clone that cannot works with untouched original sof~~~~e with a cloned serial
    (blacklisted)
    In this case its erased and you need a dump fora version of vcds
    As I know this you will cannot find it for free and even if you wanna buy it
    A dump it will be very expencive and it will not worth.
    The better way for you is to find a HQ cline that cannot be damaged and you can upgrade it and use original softwares to upgrade it.
    Or buy a genuine tool
    Or buy another clone as yours and take care in the futhure
    Good luck
  16. The Following User Says Thank You to mattydr67 For This Useful Post:
    paro44 (3rd February, 2016)
  17. #102
    Oct 2011
    Quote Originally Posted by mattydr67 View Post
    (blacklisted)
    Good luck
    Thanks for your quick answer, i will make some capture connected to the car. But it's a french version. The message explain that interface is connected to PC, but not plug into the car. (It's strange that my led is stay off) I would like to test the regulator.
  18. #103
    Oct 2008
    On Earth
    If the led its off even you plug it to the car
    - no supply voltage ( bad connection )
    - 7805 ( voltage regulator ) is defective
    - wire defective
    - Atmega not flashed ( or bad flashed )
    Check it
    Obe question please. After you trued it with original software you realized that the led its alwys turned off?
    And the vid/pid was changed maybe
    Good luck
  19. The Following User Says Thank You to mattydr67 For This Useful Post:
  20. #104
    Oct 2011
    - wire defective
    Check it
    Good luck
    Today i check the regulator and the 5V is ok.
    When i put the 12V i have 1s the led on and after it stay off.
    For the vid/pid i don't know the one before.
    I put back the VCDS version link to my cable and i still have the issue.
    For the bad flashed do you think the flash with "eXtremeBurnerAVR" is bad ?
  21. #105
    Mar 2011
    If bought sklad66
    email:
    skype:
    NO PERSONAL INFO IN POSTS !!!
    Last edited by gmb45; 4th February, 2016 at 07:10 PM. Reason: no personal info mate !!!
