If the LED is off (at all) then you do not have + 12v power on the OBDII socket. Check the fuses. Or you have some security.
Well, I think the cable is damaged. After connecting to the OBD II the diode should light up.
Led off - could be wrong fuses, bad flashing.
Usbasp migth wake-up the cable ..
can convert vag com with atmega 162 in vag can pro?
No. It is not possible to use (convert) the vag com, vcd$ cable with software vag can pro.
Just buy a vag can pro. ($ 11-20)
Happy new year, DK team!
I wanna share with you an issue with a cable from obd2cartool.
I tried to make it worked using usbasp with dumps from 18.2 to 18.9.0 , using loader v.7 to v7.2 but no luck, after I connect cable to car works about 20 seconds and program freezes and it is necessary to disconect usb cable in order to connect again.
I tried on pc with win7 and 10, with Audi A4 , Golf mk6 , Caddy, same behaviour with all.
I used same dumps/loader/18.9.0 with an identical cable and worked ok, it is not about the reflash.
I try to solve things with obd2cartool client support but, at first they said they not sell HW 44 (see pics from they site), after a while they admit to sell it, but keep ...talking with no real help, to bad..for them.
So, migth be a FTDI problem?
can be bad 7805 gets hot and not delivers 5V anymore... but also can be like atmega or anything else.. many those parts are from gray market..
Hi i also have a problem. I gained a unofficial cable 18.2.0 and stupidly updated it beflre rereading the ebay description. So ofcourse my cable is bricked. Its a good quality clone. But ive been led to believe a reflash could bring it bqcl to life. Does anyone have a walkthrough on this process ? Woth pictures too ideally. Its a hex + can, id show a pictire of my board but cant seem to see an upload option
I dont know if someone has uploaded these..
a flasher for vcds,and the 6.3 loader that work with 18.2 version perfectly.
I had some vcds cables,i wrote eeprom 1.95,license,then updated firmware.and now they work..
Hi. Sean42 on this page is manual how to repair or update the vcds cable with the ATMEGA 162 chip.
https://www.drive2.ru/l/513755880123007187/
In Post Stelaras 26 above you have everything (Kolimers Loader v 7.2) what you need for it. The condition is one: CHIP ATMEGA 162 in side. However, you should read the topic: VAG-COM / VCDS EVERYTHING there is everything.
art64 (26th January, 2019), Col19 (29th January, 2019), Stelaras26 (2nd May, 2019), Tuono (19th February, 2019)
Hi friends i join you, this is my first message Thank you for accepting me among you.
I have a cable 18.2 FR and 17.8 FR Hex V2 my goal is to understand how to perform the program of the unforgettable man "KOLIMER" and i come across the sharing of Mario6
Great !!!
It starts very well,
thanks and respect for this sharing.
Hello there! Recently i bought a vcds HEX-V2 from China. This fu*****ng seller send to me without any software, just a docx file with the installation guide. He said that use the VCDS 18.9 software release and a VCDS Loader. There is any chance to find this Loader?
The unit will work with the original software from Ross-Tech or I must search and for a cracked software?
Thanks in advance
If you try R@$$teh software, you migth "burn" the cable. So, ask seller for download link.
