Results 1 to 14 of 14
    Default Big problem Audi A5 2010 after crash, steering is always unlocked
    Hi.
    I have error in no5:
    02811-control module for steering column lock,014 Defective.
    Steering column is always open. I change this module with second used one and I swap motorolas mc908gr (4L35K) but I have the same error. Car don't have ignition, only display (steering defect). If I manuali close steering lock after connect to car it open even without key.
    Audi A5 after crash but little. I have to change this module without swap moto there is a error:
    02811 - control module adaptation bad ...
    and the dash don't display (lcd black).
    Please help
    best regards
    Adam
    Ashraf6119's Avatar
    UK
    Hi Adam,
    What Scan Tool are you using to read this vehicle ?
    Also can you do a full auto scan to see if there are any other faults in any other modules
    02811 - Ross-Tech Wiki
    Hope this link helps a bit...............
    Thanks Ash
    Oh yes if my post was helpful than Please don't forget to press the Magic word Thanks
    I know ross-tech wiki. I am using VCDS and VAS. Number of this module: 8K0905852D. I don't have full scan. This car is 20km away from me.
    Hi, I have the same problem in A5... Does anyone managed to with it or just replace the locking-module with a dealer audi-vw?
    Maybe someone has a wiring diagram to locking module in Audi A5 2009y?
    Thanks!
    genius76's Avatar
    Dec 2012
    Lowestoft
    wiring check the power
    Where do you find m8 this chip?
    I need wiring diagram supply to stering lock control module
    genius76's Avatar
    Dec 2012
    Lowestoft
    Sorry I misunderstand about the wires
    What's wrong with Chip?
    genius76's Avatar
    Dec 2012
    Lowestoft
    strongly believe that it is ignition switch faulty
    faulty mode in open position always
    DK Veteran Albanais's Avatar
    Tirana
    I had once this problem with a renault megane. I supose that this vehicle is keyles. So after many reserches i managed to reepair the fault with help of the hammer.
    Vehicle recognizez the key card but steering unlpcked, on the display. I hammered a litel bit the steering columb and the steering unlocked automatically.
    Learn from the mistakes and live the life.
    genius76's Avatar
    Dec 2012
    Lowestoft
    Albanais
    At its safe mode due to failure, which means always unlocked not locked
    Tirana
    Quote Originally Posted by genius76 View Post
    Albanais
    Agree with you, viceversa, it could be stucked in open position, isn't that?
    Senior Member ana_11's Avatar
    EU
    Quote Originally Posted by mellon View Post
    Hi.
    Please help
    best regards
    Adam
    What tool to read this mcu??
    Best Regards
    Simon
  13. #13
    This problem is described in ELSA (TPL) and solved only with renew steering lock and reflash BCM II (or renew BCM II too). Look in ELSA TPL or in ERWIN AUDI (online).
    Propably it is special bug (one of many deliberately designed) from Audi producer to kill cars after guarantee.
  14. #14
    Jun 2012
    ALGeria
    yes, carmelasse, i think lik u
