Results 1 to 7 of 7
Thread: open box 500c
    Oct 2010
    Default open box 500c
    my open box will not load up it was working fine now not
    i no haw to do the dreambox on sat side is it the same
    what will i need to reflash my box
    i need to retreive my line first so haw do i do the that
    DK Veteran Sirus's Avatar
    Nov 2008
    Quote Originally Posted by damo2010 View Post
    It is the same process as dreambox
    Use a null modem cable to reflash, or whatever you used for your dreambox flashing.
    I'm no networking expert but cant you just reflash and then get the line again from your provider, then just put it into the box again?..... also if your box wont boot then chances are the image may be corrupted, so the networking on it wont work properly anyhow... I don't think so anyhow, as far as getting into the previous setup on it.
    Feb 2012
    Default openbox 500c
    My box just froze up tonight iv been told it needs re-flashing but I cant find the file's can anyone help....Pleeeease
    Jan 2012
    Shite Link King Shady's Avatar
    Dec 2010
    192.168.1.xxx
    50/50.. Them usb jobbies are nowhere near as good as a proper null modem cable..
    Junior Member scarface1980's Avatar
    hi guys need some info back in the day i had a strarview 5 we all know what it was used for any way is there a latest box out there i keep seeing a little chitter chatter about open box and dream box would like to purches 1 of these please help
    Default Openbox
    Hi all
    Its a common fault boot failure, my supplier replaced it without quibble hope yours does to.
    Good luck
