Results 1 to 15 of 15
    Nov 2011
    Default Pug 407 FAP off 2.0hdi
    Hello,car is peugeot 407 2.0hdi with ecu siemens,i atach original file from car if someone could remove FAP correctly,ecusafe not work and car make regeneration and smoke
    Quote Originally Posted by Roader View Post
    Not free solutions for this ecu sid803..ecusafe,swiftec not work without regenerations.Ask " Alexs307" maybe help you.
    sid803 stupid ecu..calibrations(maps) in mpc555;service history stored in flash;km,pin code in eeprom
    Nov 2011
    i have to make this ecu with BDM only right?
    Nov 2011
    no one can help?
    I can help. Write to me in PM.
    ALGERIA
    no one can help?
    see at adress 52AE8 there are 5 maps of egr
    try this solution and post the results on the forum ..
    This solution works fine?
    Newbie YYougoBoss's Avatar
    Quote Originally Posted by grinovsky View Post
    Hello, for EGR removal ? how to do this ( i have the same ECU with same motor ( 307 2.0hdi ) ) ? Thanks
    Sorry for my English, I'm French
    Apr 2012
    Wink
    Quote Originally Posted by Theoros View Post
    this solution is bad,as a ecusafe
    Apr 2012
    Quote Originally Posted by YYougoBoss View Post
    not very easy remove egr from sid803.
    If you want to help you out,post dump first
    2 AGS, here is my dump. I test remove dpf ecu, use ecusafe2 dump, but ecu write P0000 fault, and not work good.
    Or if work only emulate DPF presure sensor, and still have original ecu file in SID803A.
  13. #13
    algeria
    Default 407 REMOV FAP
    Hi your dump without fap
  14. #14
    This solution doesn't workinkg!!!!!
  15. #15
    LaraVAG's Avatar
    Jun 2011
    This is one of the most easy fap to remove, swiftec do it perfect!
