Results 1 to 4 of 4
    DK Veteran standarren's Avatar
    Jun 2008
    BIRMINGHAM
    Default using wav file as ringtone
    had a wav file for my phone for a while then decided to root phone with gingerbread v12
    i've tried to play the wav file on the sd card but nothing happens
    i moved them off the sd card to my pc to check and all is ok
    any one no what i'm doing wrong
    there showing up but wont play
    happy_highlander's Avatar
    Aug 2010
    Same as any other audio player. Whatever player you have on the custom rom does not have the codec to play wav files. You can either find a codec pack from your rom dev or install another audio player
    Jun 2008
    BIRMINGHAM
    Quote Originally Posted by happy_highlander View Post
    thanks for that mat i've tried installing other players but still nothing i will have to have a mooch about
    Aug 2010
    If you can find a voodoo sound kernel that is compatible with your rom you should be ok. I have voodoo on my sgs and can play wav files
