New Vu Beta Drivers 09-11-2011
Results 1 to 4 of 4
    Sep 2010
    Default New Vu Beta Drivers 09-11-2011
    To use these drivers open the relevant archive using winrar
    now navigate to
    lib/modules/2.6.18-**/extra
    on your box
    backup the files in this folder first then overwrite them with the ones that you download, there should be four files in total.
    once the files have been transferred exit out of the FTP program and start a telnet session ( DO NOT REBOOT THE RECEIVER YET. )
    once you have logged in issue the following command
    depmod -a
    after issuing the mentioned command you can now reboot the receiver.
    also please note these are beta drivers and as such you should always backup your existing drivers in case things go wrong and you need to go back to them. as always if your unsure about any part of this leave well alone.
    20111109
    - Improve media playback
    - Add interface to control VFD in the application(ultimo)
    ultimo
    http://archive.vuplus.com/download/drivers/beta/vuplus-dvb-modules-vuultimo-2.6.18-7.3-4.4.3-20111109.tar.gz
    uno
    http://archive.vuplus.com/download/drivers/beta/vuplus-dvb-modules-vuuno-2.6.18-7.3-4.4.3-20111109.tar.gz
    solo
    http://archive.vuplus.com/download/drivers/beta/vuplus-dvb-modules-vusolo-2.6.18-7.3-4.4.3-20111109.tar.gz
    duo
    http://archive.vuplus.com/download/drivers/beta/vuplus-dvb-modules-bm750-2.6.18-7.3-4.4.3-20111109.tar.gz
    Sep 2010
    - Fix skip problem in media playback
    ultimo
    http://archive.vuplus.com/download/drivers/beta/vuplus-dvb-modules-vuultimo-2.6.18-7.3-4.4.3-20111110.tar.gz
    duo
    http://archive.vuplus.com/download/drivers/beta/vuplus-dvb-modules-bm750-2.6.18-7.3-4.4.3-20111110.tar.gz
    solo
    http://archive.vuplus.com/download/drivers/beta/vuplus-dvb-modules-vusolo-2.6.18-7.3-4.4.3-20111110.tar.gz
    uno
    http://archive.vuplus.com/download/drivers/beta/vuplus-dvb-modules-vuuno-2.6.18-7.3-4.4.3-20111110.tar.gz
    Sep 2010
    - Fix HDMI CEC problem(wakeup from standby)
    - Reduce zapping noise in some A/V Receiver
    - Fix Recording/Playback problem
    - Fix High bitrate tuning problem(Uno, MUST Need a FPGA update,
    - Change temperature calculation algorithm.(uno, ultimo)
    - Change the lowest FAN speed(ultimo)
    - Fix incorrect keycode in the remote control(ultimo)
    now navigate to
    on your box
    depmod -a
    To use the FPGA update file ( UNO ONLY ) unrar the file and copy the ( TS_PRO.dat ) file to a memory stick or to TMP on your receiver, now go to plugins and you will see a FPGA update option there, press this and navigate to the file you placed on your usb stick / receiver. This update takes around 5 minutes to complete.
    THESE DRIVERS ARE NOT BETA DRIVERS THEY ARE THE LATEST FULL RELEASE SET BY VU
    a911's Avatar
    Lost-in-Space
    Question
    Is there a new driver update for Duo as of today ?
    RgdZ
    a911
