hello
post picture of your ECU insid
Hello. I have a problem with this car.
I need the boot mode for this ecu.
Renault Scenic 2 - 1.5 DCI - DDCR - With Galletto Original
In the documents there is this picture but my ecu is not equal, it 29F200 flash but do not have those points to make the boot mode. Please I need help. Thank you.
I need to correct the checksum, because I winols corrects the checksum.
hello
Problem solved. I read the ecu for obd.
thanks.
Just make boot on processor pin. Pinout for the C167 processor is the same, no matter in wich ECU it is.
InfoPerformance:"Problem solved. I read the ecu for obd."------how the problem is solved?? Share please??
Hello.
Which tool read/write full flash(256K) from Megane 2 1.5dci DDCR Delphi Ecu?
Use flash pin 24 with 1kohm and works fine
2WD Dyno , Magpro2 X17, FLEX Master , KESS Master , AUTOTUNER Master, Byteshooter Master, EVC Winols Reseller
Official Magicmotorsport DistributorCode:FILESERVICE: Tuning / DPF / EGR / Adblue / DTC / Immo
Official Autotuner Distributor
Official Alientech Distributor
