Results 1 to 13 of 13
    Member dreamvictim's Avatar
    Default Help with Zafira Z16XE fault codes
    My friend has a Zafira with the Z16XE engine. The engine management light came on but it has no noticable problems when driving. I got the following codes off it from opcom but they won't clear.
    Total number of fault codes: 7
    P0300 - Misfire Detected at Low Fuel Level
    (0B) - Not present
    P0304 - Cylinder 4 Misfire Detected
    (00) - Not present
    P0351 - Ignition 1 Control Circuit
    (00) - Not present
    P0352 - Ignition 2 Control Circuit
    (00) - Not present
    P0353 - Ignition 3 Control Circuit
    (00) - Not present
    P0354 - Ignition 4 Control Circuit
    (00) - Not present
    P0420 - Catalyst System Low Efficiency
    (00) - Present
    Anyone got any ideas?
    smokey08's Avatar
    Essex, UK
    What version of opcom are you using? I had same problem of not being able to clear the codes and I downgraded opcom to 09714 and then it worked.
    DK Veteran Larue's Avatar
    Somerset, UK
    Last fault code is the right one. Just clear them all and see what's coming back.
    If only P0420 then it's worth to get car for good run on the motorway. If this doesn't help then needs new CAT( catalyst converter).
    I must be having opcom trouble then, it's always cleared codes before so i'll reinstall the drivers and try again.
    DK Veteran teuton's Avatar
    Mexico
    Reinstall op-com and clear codes. prob P0420 will come back after a short while and you'll gonna need to change the catalytic converter. You could check converter with IR-thermometer.
    Yesterday we stood in front of the abyss. Today we'll move ahead.
    If you need any repair manual, pm me- maybe I can help you.
    Meat-Head's Avatar
    Quote Originally Posted by teuton View Post
    Can you just remind the viewers at home about the thermoeter test please. - Some members don't know - some have forgotten!
    dopsleutel13's Avatar
    Dutch
    The temperature test:
    For this test requires a digital pyrometer. Drive your car with an increased number of rotations per minute for about 2 minutes (about 2,000 rpm), to ensure that the catalyst has enough time to activate. Now, you examine the temperature of the test head of the pyrometer on the front of the catalyst and then the back. The temperature at the back should be higher than the front, if the opposite is the case, the catalyst did not work properly.
    antwnhszr's Avatar
    macedonia is greek....
    Quote Originally Posted by dreamvictim View Post
    (0B) - Not present
    (00) - Not present
    (00) - Not pres
    (00) - Not present
    (00) - Not present
    (00) - Not present
    (00) - Present
    Good morning my friend ... Is the car before recording the damage had BODY; there a earthing over the chassis is not in position; Search and this possibility and do not you hear the diagnostic
    Mexico
    On a proper workin systen the outlet temp will be some ~ 50 degrees celsius higher than on inlet. If inlet temp is higher than the catalyst doesn't work anymore. If in/out temps are the same then the converter is clogged.
    greetings
    Reinstall op-com and clear codes. prob P0420 will come back after a short while and you'll gonna need to change the catalytic converter..
    Thanks for the replies guys!
    Apparently it had a new cat just a couple of months ago.
    DK Veteran tapiru's Avatar
    Is this cat a genuine one ? Asking this cause many owners use to mont that shity universal cat who are not good but cheap at 20-25% like original one
    Ashraf6119's Avatar
    UK
    P0420 code is not always faulty cat it could also be your lambda Sensor faulty............the other word I could say a Lazy Lambda Sensor..........So the best way is to monitor your rear lambda as well before condemning your Cat............
    Here is a link which tells you how to test the Cat.......
    [ame="http://www.youtube.com/watch?v=Qrj_ioWCkQI"]How to test a catalytic converter on the vehicle - YouTube[/ame]
    Here are some more test where you can rule out if the cat is faulty or not..................
    [ame="http://www.youtube.com/watch?v=9TlygJMxTps&feature=related"]Testing for a plugged, clogged, restricted exhaust, converter - YouTube[/ame]
    Hope this helps...........
    Edited: Here are some info about Lambda Sensors................
    http://www.lambdasensor.com/main/mtesting.htm
    http://ngkntk.co.uk/index.php/techni...ambda-sensors/
    Last edited by Ashraf6119; 23rd November, 2011 at 09:57 AM. Reason: Added some links for Lambda Sensors Test
    Thanks Ash
    Oh yes if my post was helpful than Please don't forget to press the Magic word Thanks
  13. #13
    Meat-Head's Avatar
    Quote Originally Posted by Ashraf6119 View Post
    P0420 code is not always faulty cat it could also be your lambda Sensor faulty............the other world I could say a Lazy Lambda Sensor..........So the best way is to monitor your rear lambda as well before condemning your Cat............
    HI
    THATS AN COOL LINK THERE, THE FIRST EMERICAN BLOKE MADE HIM SELF LOOK FOOLSIH BY SAYING IF THE CAT IS BAD PRESSURE WILL BE 2.5 PSI - BUT IT WASN'T
    THEN THE SECOND EMERICAN BLOKE - DID HE NOT READ THE FAULT CODES - EG MISFIRE, P0420 - IF HE SUSPECTED A 'PLUGGED MUFFLER' WHY NOT JUST UNBOLT IT.
    NICE LEARNING EXERSISE.
    MEAT
