Results 1 to 15 of 15
    DK Veteran teuton's Avatar
    Nov 2009
    Mexico
    Question firmware upgrade of op-com
    Can any1 tell what would be the benefiit from upgrading op-com firmware from version 1.33 to 1.39?
    Thank you.
    Yesterday we stood in front of the abyss. Today we'll move ahead.
    If you need any repair manual, pm me- maybe I can help you.
    Nov 2009
    Mexico
    ---------------BTT----------------
    Nov 2009
    workshop
    "opcomfut"usefull help,you can find on DK
    Oct 2008
    On Earth
    You can do a firmwear upgrade just using the last cracked sw , the OPCOM 090821.
    After you instaled the driver, run an interface test and then the sw will upgrade your firmwear automatically.
    If you haven't skills to use the OpCOmFut you can do it in this way, it is much more easier.
    Good luck
    Nov 2009
    Mexico
    Quote Originally Posted by mattydr67 View Post
    You can do an firmwear upgrade just usind the last cracked sw , the OPCOM 090821.
    After installing driver, make an interface test and then the sw will upgrade your firmwear automatically.
    If you can't hendel the OpCOmFut you can do in this way, it is much more easier.
    Good luck
    Thanks for your reply, but what is the advantage of the upgrade? Or is the upgrade just necessary in order to run the latest software?
    Oct 2008
    On Earth
    Quote Originally Posted by teuton View Post
    Ok if you upgrade your interface you can use a new updating sw and you'll have acces to a new function aviable in new versions.
    What version of OpCOm do u use?
    Nov 2009
    Mexico
    I just got a new interface, the sticker says 090820b version. It came with two folders one before and one after the upgrade
    Oct 2008
    On Earth
    This is a stupid way to upgrade an interface.
    Chinese brand, I know that.
    All Chine clones came with this on cd.
    It is an unuse sw. it dosen works well, it has bugs.
    Better is to use this OpCom 090821 or 090714
    it was posted here but now is gone.
    i have it but now I don't know if I can share it. I don't want to be banned.
    Good luck
    z786's Avatar
    Aug 2009
    10 Steps Ahead of You
    check attachment in post #3
    http://www.digital-kaos.co.uk/forums...44/#post733653
    upgrading is recommended, better for you
    "I always tell the truth. Even when I lie"
    "We Taking Over, One City At A Time"
    DK Veteran mishu_b's Avatar
    Jul 2009
    Land of Choice!
    answer to your question:
    without fw update you can not run new sw. in fact one you run the new sw this will do automatically fw update.
    br
  11. #11
    Dec 2010
    RUSSIA
    How to upgrade OP-COM firmware from version 1.39 to 1.43?
    Thank.
  12. #12
    Sep 2009
    Run 110110a version and your fw upgraded to 1.43
    but 1.43 can't downgrade by any utility now, only by external pic programmer
  13. #13
    Nov 2011
    there is a tutorial to update from 1.39 upgrade to 1.44? Thank you! I have not found one
  14. #14
    Jul 2009
    Land of Choice!
    Quote Originally Posted by laurentiu83ro View Post
    easy tutorial - install the last released OP-COM sw - run test interface - and your tool will be automatically updated it.
    atb
  15. #15
    einet's Avatar
    Dec 2009
    and wher is the cracked version for 1.44?
