BlackHole Vu+Uno mod by ACJ Team 1.6.3 Hdmi Cec
We are pleased to present this new image MOD (modified) by the team of YMCA Team.
This image is based blackhole Hdmi_Cec 1.6.3 but on our part we have included some interesting little things so serious flash your Vu + One with a USB and dispondreis instantly:
Emus:
CCcam
CCcam + sbox
Emus Versions of:
CCcam 2.1.3
Sbox: the Last Today 0.0.5-0 SBox Public # 2
I put your line card configurations in the default files or replace yours.
Plugins:
Dream Explorer 7.3
Manual Fan Control (the fan stops in standby, adjust speed) if you will. :-)
But all the plugins that comes by default the image that are not few, Media Scan, Web interface, My tubeplayer, CrossEPG downloader, etc, etc ...
Skins:
Beyonce silver
Black Shadow 3
Wall HD (default skin)
HD-X1
Smoke Pro HD
To which most handsome :-)
Picons in Flash:
Path / media / usb / picon
HD Picons Licher by 13 ? 23.5 ? 19.2 ?, 28.2 ?
Impresionanates :-)
Scipts boot:
Only CCcam CCcam or more Sbox
Select Common Interface default in Blue panel to taste.
Nothing is more active work <<**** and giving OK
Atomic time server:
Ntpdate
# Function ntpdate to set the Vu + One hour.
# Ideal for decos servers that do not look at Satellite.
# If "****" repeated log record, one after another.
# If ">" log record crushes every time you create a new one.
# Hash for convenience.
By dimoni68 # # # # # #
With this we avoid this in binary or CCAM sbox
Current time 22:26:03
NodeID: xxxxxxxxxx
Uptime: 12:07:48 43210d ji means not :-))))
Full explanation under / usr / camscript
9015 Afatech DTT USB and running:
Afatech dirvers installed in 9015 and is the same Volar Black HD 9015 or driver support.
Channel list Province of Barcelona, ***8203;***8203;if you do not like, delete and make a new search in your area.
Default setting:
User: root
Password: acjteam
Language: Spanish
Ip: 192.168.1.111
DHCP: No
Net Sub: 255.255.255.0
Gateway: 192.168.1.1
Primary DNS: 192.168.1.1
Beginning word: Tele Madrid Sat
DiSEqC: USALS Motor (change to your coordinates) or put your DiseqC
Channel Lists:
Motor settings Vhannibal E2 July 19, 2011
Who gives more :-))
Occupies in Flash:
vuuno root @: ~ # df
Filesystem 1K-blocks Used Available Use% Mounted on
/ Dev / root 116 736 76 192 40 544 65% /
udev 2048 52 1996 3% / dev
/ Dev/mtdblock2 388 4096 3708 9% / boot
tmpfs 151556 236 151 320 0% / var
4 151 552 151 556 tmpfs 0% / tmp
151 556 151 556 0 tmpfs 0% / dev / shm
Free memory:
vuuno root @: ~ # free
Used total shared buffers free
Mem: 303116 110684 192 432 0120
Swap: 0 0 0
Total: 303116 110684 192432
Hard Drive:
If you ride hard drive, fstab takes care of it without you any more, initialized and ready.
(Back Hole Device Manager can help you too.)
By ACJ Team
http://www.megaupload.com/?d=KEG0FMO0
