Results 1 to 15 of 17
    May 2009
    Default Speed limit ford transit, ids only?
    Can anyone confirm that speed limiting ford transits 2005 onwards can be done with aftermarket tools like X431 diagun or Autocom ?
    is Ids the only option, any ideas of a good supplier, and where do you find the option to set.....pcm,bcm or dash?
    thanks in advance
    obd
    Meat-Head's Avatar
    have you tried screwing a block of wood to the floor - stops gas pedal being pressed
    florinyes's Avatar
    London Middlesex
    He probably wants to derestrict it??
    Whatever seems impossible is just not yet important enough.
    Meat-Head's Avatar
    Quote Originally Posted by florinyes View Post
    OK, point taken:-
    If you find a piece of wood under the gas pedal - remove it - see if that fixes the problem.
    HTH
    Meat
    autotuning's Avatar
    Default 2205> Transit Speed Limit
    IDS of course but and be aware that pre 2005 is a full download with IDS to install or remove a speed limiter post 2005 can be done in the flash with tuning software OR Autoboss V30 will do speed limits unless it has a tacho fitted as in a minibus
    Dave
    May 2009
    thanks guys.......and meat.....made me smile yet again.
    no wood fitted.......boss wants to cut down on his workers fuel consumption and speeding tickets.
    what module is the option available in?
    w.yorkshire
    if you have access to ids i can give step by step guide if you give van details...year etc, regards steve
    Hi digi-dash can you give me the step by step procedure to add and remove speed limiters for the transit range please.
    Hi digi-dash I tried to pm you but it says you have exeeded your stored messages and need to remove some before you can accept anymore, I am looking for step by step info to remove and add speed limiter to transits from 2003 - 2012 using IDS any inf will be of help.
    florinyes's Avatar
    London Middlesex
    Just play a bit with IDS and you'll find it quite easy under the service functions menu.. You'll have a number of options like miles or KM, restrict or derestrict etc..
    Hope it helps
  11. The Following User Says Thank You to florinyes For This Useful Post:
    waylyn (15th August, 2013)
  12. #11
    Thanks florinyes, the guy has 18 vans he wants to restrict to 70mph, so I hope this is in the presets or maybe I could enter it manually.
  13. #12
    florinyes's Avatar
    London Middlesex
    You just tick the option 70mph..
    Easy one..
  14. #13
    w.yorkshire
    try this, regards steve
  15. The Following 4 Users Say Thank You to digi-dash For This Useful Post:
    busaman (22nd November, 2013), gedym (13th December, 2013), genius76 (17th August, 2013), waylyn (17th August, 2013)
  16. #14
    Thanks digi-dash very helpful,
  17. #15
    darrenhyland's Avatar
    Aug 2010
    IRELAND
    autocom clone does it I think........seen it on a menu a short while back.
    Tools owned..... Kess3 Master, Bitbox, TGFlash, VVDI2 Full, VVDI Prog, VVDI MB Tool, VVDI Mini Tool, VVDI Key Tool Max Pro, VCX series for BMW Ford Mazda Jaguar Land rover VAG Toyota Volvo GM, PCM Flash + Scanmatik2, Lonsdor K518ise, Magic tank and every other piece of Chinese crap out there.
